Uncoupler doesn't work on Lionel 6019 remote control track
I have a Lionel 6019 Remote Control Track with an unresponsive electromagnet uncoupler. The uncoupler button operates the power rails for accessories like the barrel car and the Stockyard Cattle Car, but at slightly less power than the Unload button, which works perfectly. I have carefully replaced the black ribbon wire from the switch, and I can’t see where I made any incorrect connections. The contact springs appear to make contact when I depress the buttons in the switch. Is this worth messing with further? Could the electromagnet be bad? I would appreciate any suggestions or instructions about how to troubleshoot this accessory to get the uncoupler working–if possible. Thanks.
Tooth Fairy,
You will have a better chance of having and or receiving help from the Classic Toy Trains forums. ctt.trains.com. to access the site quickly…go to the bottom of this page where You posted Your msg. scroll down to the black bars, where it shows Kalmbach publishing next to it You will see Classis Toy Trains, click on that and it will take You to the site…once there, hover over community and Forums will show click on that and ask Your questions there.
HO-scaler’s and N-scaler’s mostly hang out here.
Take Care! [:D]
Frank
