underneath the 036 fastrack switches
wires going from the SC-2 switch controller to the 036 fastrack switch where do i connect the wire underneath the 036 fastrack switch i dont understand the 036 fastrack switch manual please help[?]
It’s covered on page 10 of the manual?
Lionel recommends not using terminal one on the SC2 for FastTrack Switches. I’ve never had a problem BUT, I may have been lucky. If you use any of the other terminals on the SC-2, the Thru terminal on the SC-2 goes to the THRU (Green) terminal on the switch bottom. The Ground on the SC-2 goes to the GND (Black) on the switch and the Out/Y on the SC-2 goes to the OUT (Red) on the bottom of the switch.
