underneath the 036 fastrack switches
wires going from the SC-2 switch controller to the 036 fastrack switch where do i connect the wire underneath the 036 fastrack switch i dont understand the 036 fastrack switch manual please help[?]
**Kurt…**does this mean your mind has drawn a blank? [:D]
I started describing SC-1…and it’s SC-2, a bit more complicated…and I needed to stop and pick-up my daughter from school…er…I mean… yup.
It’s covered on page 10 of the manual?
Lionel recommends not using terminal one on the SC2 for FastTrack Switches. I’ve never had a problem BUT, I may have been lucky. If you use any of the other terminals on the SC-2, the Thru terminal on the SC-2 goes to the THRU (Green) terminal on the switch bottom. The Ground on the SC-2 goes to the GND (Black) on the switch and the Out/Y on the SC-2 goes to the OUT (Red) on the bottom of the switch.
What do i use for accessories do i use a 1.8 amp accessory transformer along with the SC-2 accessory swith controller please help
The switch will buzz and hunt when a train passes over the switch connected to terminal 1. It didn’t occur every time on my layout, but often enough to be annoying.
Earl
I never had the switch do anything odd. I did use an independant power supply, not the wall wart and not the track power.
