I have a pair of Lionel RS-3 Locomotives, the NYC version made a few years ago, and the newer Southern version.
I am not really sure as to why I got the NYC one originally. I remember bringing with some issues of CTT with me during a month long underway, and one morning (if submarines actually have a morning, due to the 18 hour days underway), I literally woke up and decided that I would buy the Lionel NYC RS-3. The first day off I had after pulling back into port, we went to Charles Ro, to find that they had ONE left and it had been sitting for a long time, as by that time, the engine was already replaced with the Alaska RS-3. Needless to say, I bought it, upon first startup, one of the wheels in the rear truck was found to have fallen off. Not that hard of a fix, I applied some JB weld to the splines on the axle, and pressed the new wheel on with a bench vise.
Since then, it has been a very sold runner, albiet a tad weak due to poor weight distribution. (The weight seems to be balanced between the front powered truck and the rear unpowered truck.)
What I plan on doing to both units is to install a motor in the rear truck to help with traction and to allow for a longer train without straining the single motor.
The rear truck seems to be an exact match with the front truck, aside from the lack of a motor, gearing, pickup rollers, and the rear wheels (understandably) do not have traction tires.
From what I understand of it, the reverse board on the RS-3 is the same used on the twin motored Lionel GP-38, so changing the board out should not be needed. (A new board for the GP-38 is only $13, so changing it out would not be that bad.)
Has anyone else attempted such an upgrade? If anyone has any advice and/or suggestions, it would be greatly appreciated.
James
