Hi all, i am thinking of adding a small 5x5 on the end of the layout (currently 13ft long all ready) to accomidate a 26" to 28" radius curve, i currently have 22" radius where the end of the table is now. I want to add the 5x5 and do away with that 22. Will 26-28 fit on the 5x5ft extension with no problems? Will i notice a big difference in the look of my passenger equipment (full 85ft stuff) from 22 to 26 or 28? Any one have a picture of some full length cars on 28" or under?
HOnestly, no you won’t. Not for the ranges you are talking about, at least. If you were to increase to 40", then you are talking of a substantial improvement in appearance. But the difference from 22" to 28" will be disappointing, if my experience is anything to go by. I have just gone from a layout with 22" everywhere to spline roadbed with some curves as much as 45", and many at my minimum of 28". My Walther’s heavyweights still look toylike on the 28" curves. They look darned good on the broader ones.
Go as big as you can go. This is not a all or nothing game as selector is saying.
Go for it, you will notice the difference. Even between 18 and 22", there is a big difference in appearence.
I don’t think he’s wrong - Hotshott’s original question was will he notice a big difference in the look of his 85-ft passenger equipment expanding from 22" radius to 26" or 28". No, he would not notice a big difference in the looks. He might notice a small difference, but that change is just not that great. Will it function better? Yes. Can he run faster? Probably. Will the effort in expanding be worth the results (pretty much the kernel of his question)? Only he can answer that …
I would only add that if you are going to use a 28" radius on a five foot extension, you’re going to be pretty close to the edge of your extension (i.e. two inches from the center of the track) so the track is going to be pretty close to the edge. Generally, you need approx. 6-8 inches beyond 2 X radius for the width of your table at that curve point if the curve is a 180 degree turn.
Because you are very close to the minimum practical radius for the full length pasenger cars at 22", rasing the radius to 26" or 27", especially with easements, will have much more impact on both appearance and operation than would going from 30" to 34" or 35".
A suggestion: mock it up on the dining room table with a couple of pieces of flex track and a couple of pieces of 22" radius Snap Track. See for yourself whether the difference in overhang and better performance of couplers is worth the extra effort.
My response was one of caution based on experience. One would think that the improvement in appearance would be substantial, and that is not my observation. Truthfully, even on my 40±inchers, the heavyweights still look like they overhang a lot. So, the vision that I had, of much better looking trains on the much larger curves, simply did not come about.
Of course there will be improvements in tracking, fewer derailments caused by streamlining, and improved appearance, but I wanted to warn our asker that he may have an idealized version of the result, as I did, that did not come about.
I know that his space is limited, and the increased curves would add to his pleasure. My use of the 45" was to SCALE the intervals over which he would begin to appreciate the investment in costs and effort noticeably.
contrary to the opinion of some who seem to have no evidence to base their judgement on, Selector is correct. Many years ago we widened a return loop by four inches and after all the work it really did not appear that much better. You are down near the minimum for those cars and are not making a significant change.Adding four inches to 22 " is less than 20 % increase
Walther’s Heavyweights recommend a minimum of 24"
Branchline Blueprint’s require a minimum of 28" if you want to use safety collar
A number of after-market working diaphrams require a minimum of 28"…Some are 32"!
I myself just went from 22->28" minimum on all passenger mainlines. It does appear to help tracking and appearance. But the difference is not staggering. It’s not so much the overhang, but the swing between car sections that ruins the illusion.
Anytime you have the opportunity to use a larger radius…Go for it! Of course you will notice a difference between 22" & 28" both operationally & visually, it’;s just not gonna be one of those “OH WOW” expierences…regards, John
I agree with Fred that making a mock up with some flex tack will answer your own question. I did the very same thing to come up with a minimum radius for my layout. I am still in the planning stages on it, but making this mock-up made me realize that there seemed to be a significantly better appearance to the look of piggybacks and autoracks traversing a 34 inch radius, then anything smaller. Why? Because I did not see the outer rail while looking at the train from an agle, slightly above track level. That 34 inch radius, I determined, was a good minimum for me. With your passenger cars, you may find that a 28 inch radius will accompli***he same.
Therefore, I believe the increase could be a significantly better option for your radii…just try it out first and see for yourself.
The first thing I looked at was the amout he could fit in the 5X5 area, the 28"radius has a total span of 4.7 feet. That only leaves about 2 inches at each side of the bench for the outer edges of the track. A very tight fit if you ask me, might want to increase the width of the benchwork or lower the radius a bit.
You have to just go ahead and realize that a 40" curve or greater is probably not going to be practical for 90% of Model Railroaders. While it would be nice, that would take up more room than most of us have…If you look at most of the featured layouts in the magazine, most of them are around 26" to 30".
Any improvement in radius is an improvement, so do it if you can. I recommend enjoying the fact that you have a fun layout and just have run some trains instead of worrying about a few “unprototypical” operations.
It’s more of an operating advantage than an appearance issue. If (fill in the blank) is designed to operate on 24 inch radius, it MIGHT operate on 22 inch. It WILL operate on 26 or 28 inch radius as long as there are no kinks or rail-out-of-gauge spots.
Strictly speaking, any HO curve below 48 inches, viewed from the convex side, makes longer rolling stock and big-overhang engines look toylike. Even 20-meter carlengths look improbable on 610mm (24") radius.
