I got the usa trains PA-B units and tried to install the TE board in the A unit and when I turn my 10 amp power on the breaker trips. I need some help with this one…Any ideas? I disconnected the wires from the USA baord and connected them to the TE using the diagram provided by Aristocraft.
Thanks
Chris
Can you give more details?
are you talking about the older mini 3 amp on board TE, or the track side 10 amp TE?
I run 3 Macs with the track side in a trailing car w/o problems
I have the onboard TE mini board that plugs into a DCC board or can be hard wired to the engine, and have it in an aristocraft enigne and it works fine with the 10 amp power supply. I got 2 more to install into the A and b units, but the a unit overloads the power supply. I did not install one into the B unit.
Thanks
Chris
OK I’m not a rivet counter BUT where did you get a PB from? Did USA trains start making them?
Dave
I beleive the 3 amp limit of the on board train engineer is too low for the USA PA series of engines.
I have a friend that found the ABBA unit would not run on the 10 amp TE and he had to go with a 25 amp track powered supply to run these engines.
Yep, the onboard TE cannot handle the current a PA or PB unit takes. Take an aristo trackside TE if you want to control, but then you are back at 27 MHz, your onboard is probably a 75 MHz.
I have 2 PB’s, USAT always made the B units.
You could only buy them as part of an AB set, you can buy an AB or an A but not just a B.
Regards, Greg
Just for the record, there is no such thing as a “PA-B”
there is the Alco PA (A-unit)
and the Alco PB (B-unit)
thanks,
Scot
