Hello,
I bought a used Aresto-Craft SD-45 and been abused bad!
but the problem is that it had been in “Battery” mode and it can not witch back to “Track” mode.
I used a meter and tracked power from track to drivers, to main switch board on top, but from there it stops!!! is the switch board gone bad??? or can i change the switch it self out or wire past the switch and board to get track power to get this unit on line again???
thank you for you time in this matter…
Russ
