Cut the yellow wire going fromt he DPDT tot he Tortoise. Insert the 2-leg bicolor LED there, without a resistor.
Kirchoff’s Laws - the same current will flow through all devices in series. 15ma is about what flows through a stalled Tortoise motor, therefore 15ma will flow through the LED. No resistor needed.
For red/green signals, just use a red LED and a green LED wired back to back (cathode to anode, anode to cathode) - you are simply making your own bi-color LED out of two discrete LEDs. Wire the same way.
If your power supply is 12V, then 2 sets of LEDs will still leave enough voltage for the Tortoise. If you want more than 2 sets of LEDs in the chain, you may need to increase the voltage. Each colored LED will drop about 2.1 volts - so 2 sets of LEDs is about 4.2 volts, leaving about 7.8 volts for the Tortoise. If you up it to a 14V power supply, the Tortoise would get about 9.8 volts - still less than the 12V maximum.
The downside of series LEDs is that they will change indication as soon as you flip the toggle switch, and they will be dim while the Tortoise is moving, and brighten when it completes the movement.
This series wiring is what most of us have been talking about with respect to indications and Tortoises. The Tortoise is the perfect current limiter for LEDs. Also why the Cobalt is not as good, the Cobalt is around 30ma which is too much for most LEDs.
Ah Kirchoff, been a while since io thought of that guy.
Just one addition to Randy’s excellent answer: typically you would need 2 signals minimum per switch (diverging routes), plus 1 you want Green/Yellow on the facing point side. Plus 1 more for panel. That’s a whopping 2.1x4=8.4v in series with the tortoise. So driving from a 12v supply is not an option. I would go at that point with a 16v supply.
The way I solved this is that I did not use an indicator for the facing point or the panel. To me, the position of the switch itself was enough for he panel.
Second point: I used 2x12v wall warts to make a +/-12v supply. That was $10 more but allowed me to use SPDT switches which saves so much wiring on your panel that it’s worth it totally. If you have not already built the panel, consider this. What you have to do is co connect the + of one supply with - of the other. This becomes your 0V. You will be left with two more terminals from the supplies: a -12v one and a +12v one. Wire the 0v to pin 8 of all tortoises. Wire the + and - one to the two sides (throws) of the SPDT. The pole (center) of the SPDT goes to Pin 1 of tortoise.
Here is a visual representation of what Randy is talking about. you can put two LED’s (the two LED’s are in parallel but back to back) or a bipolar LED in series with the tortoise wires. This means you do not need the resistor as the tortoise motor performs that function when it is stalled. It limits the current to the LED’s.
This is raising all sorts of questions in my mind.
First, and I should have mentioned this at the outset, I use MRC Railpower 1370 power packs for my tortoises, signals, LEDs, and DPDTs. The MRC Railpower 1370 is an 18 volt DC power pack. Is this higher voltage going to cause problems with these solutions?
Second, in a different thread, someone suggested that you must connect the LED to the #1 terminal on the Tortoise. In my illustration, the yellow wire that Randy suggests cutting is connected to the #8 terminal on the Tortoise. Is this a problem? The Tortoise instruction sheet does not list the power off of each terminal.
Third, if you connect one leg of the LED into the yellow wire without a resistor, where does the other leg of the LED connect?
Fourth, if I power my signals off of the #5 and #6 terminals of the Tortoise, do the LED wires for the green and red still need resistors.
Ugh, I have always been electronically illiterate.
Renegade’s post shows what I am talking about. You cut the yellow wire but insert the bi-color LED to complete the circuit.
If you’re using a measured 18V DC to drive the Tortoises per your original diagram technically you are driving the Tortoises with too much voltage. They are rated for 12V. If you insert 2 sets of LEDs in series with the Tortoise, it will still be getting over 13V even with the LED drops, so no, changing the circuit won;t do anything except reduce the voltage to the Tortoise to closer ot the rating. ANd it will run quieter. The sweet spot I’ve found seems to be about 9V, enough to mve them at a reasonable speed and hold, but MUCH quieter than the full 12V. Coincidently just about what you’d get using a common 13.8V (common because this si the real voltage of a “12V” car battery - so for devices that are meant for mobile use, a 13.8V wall wart is used to run them on house current - also it’s good when runnign a 12V voltage regulator), and 2 sets of LEDs. 13.8 - 4.2, 9.6V.
Total current load per unit (A tortoise, plus 2 sets of bicolor LEDs) is still only 15ma, because the LEDs are in series. They way you have it set up now with parallel LEDs, yoy actually have a total current draw of 15ma for the Tortoise + whatever current is in each LED based on the resistor value you are using. So overall power requirements for your layout will actually drop using the series LEDs.
The good news is that it works, cutting the yellow wire and inserting a bi-color led to complete the circuit.
The bad news is that I don’t get it. If somewhere between 12 and 18 volts are coming up to the DPDT from the DC power supply, what keeps an unresistored LED from immediately burning out?
Our club uses a single, 20ma, 3mm green/red bipolar, two lead LED in series with one lead to the Tortoise. We use to use 12 vdc but lowered the voltage to 9 vdc for slower point operation.
We used a LM317 voltage regulator, two resistors and two caps to have regulated 9 vdc for the turnout motors.
It doesn’t matter if the LED’s are on pin 1 or pin 8 of the tortoise. one leg of the LED will connect to the tortoise (pin 1 or pin 8) and the other will connect to your DPDT switch. Another wire will run in from the opposing pin on the tortoise to the other side of the DPDT switch. See my diagram above.
The tortoise swtich machine acts as your resistor. The switch machine is the current limiter that keeps your LED’s from burning out. Remember LED’S are CURRENT driven devices. As Stated you potentially damaging your tortoises by running them at 18 volts since they are only rated at 12 volts.
Ohm’s law will help you determine the right size resistor (which you don’t really need if you are putting inline with tortoises). the formula is V= I*R where V=Voltage, R= Resistance and I= Current. Generally the max current you want to put thru a LED is around 15 milliamps (0.015 Amps). So if we rearrange the equation R = V/I. If you have an 18 volt power supply it would be R= (18 volts) / (0.015 Amps) which gives you 1200 Ohms for a resistor. This is the minimum size resistor you would want to use for an 18 volt power supply.
You can have higher voltages but you need the correct size resistor.
Go back to my first post. It’s one of Kirchoff’s laws, all elements of a circuit ion series will have the exact same current flowing through them. A Tortoise is 15ma, ergo anythign in series with the Tortoise will also be 15ma.
To do the same witht he signal, just stick it in series witht he other LED and Tortoise motor wire. Or the other Tortoise motor wire, it really doesn’t matter. For simplicity’s sake - one wire fromt he DPDT to the Tortoise pin 1. The other wire from the DPDT to one side of the bicolr panel LED. The other side of the bicolor panel LED to one side of the signal LED pair. The other side of the signal LED pair to the Tortoise pin 8.
That’s assuming the signal LED is actual a red and green LED hooked up back to back - like I said, making the same thing that a 2 lead bicolor LED is, just using individual LEDs. That’s all those bicolor LEDs are, two LEDs in one case.
I mentioned earlier in this thread that I was using an MRC Railpower 1370 to power my signals, Tortoises, DPDTs and control panel LEDs. I indicated that the power pack was 18 volts.
I was concerned after reading the comments about the recommended voltage to the Tortoise, so I used a volt meter to test the output of the MRC Railpower 1370. I got a reading of 13.25 volts. Good news for the Tortoise, but I wondered what happened to the alleged 18 volts which are the stated voltage on the MRC web site.
Turns out, in reading the operator manual, that the the voltage is less. Here are the stated voltages.
Output - 15V DC, 19V AC
Total Output - 18 VA
So, the DC voltage is actually 15, not 18.
When MRC says that Total Output is 18 VA, what are they referring to?
Why use the word “Total”?
And what does the A stand for in 18 VA ?
And, finally, why do I get a reading of 13.25 volts if the power pack says 15 volts?
18 VA is 18 Volt-Amps. It is similar to watts, though not exactly the same(volt-amps uses RMS values). For example, if the power pack can provide 18 VA at 12 volts, that would be approximately 1.5 amps(12 volts x 1.5 amps = 18 volt-amps).
If there was any load at all on the power pack when you measured the voltage, that would explain the difference in the rated voltage and what you measured. Since the power pack is not regulated, any load on it will cause a drop in the output voltage.
Well, so it’s 15V not 18V, you’ll still be fine with 2 sets of LEDs in series with the Tortoise, that gives you about 10.8 volts to the Tortoise, which is plenty.
