Some time ago I saw a video where the person had devised a way to stop trains rolling off the layout when a lift out bridge was removed using an Arduino. The device was triggered by the removal of the lift out bridge. The Arduino would then raise two small piano wires to block the tracks on both sides of the gap. I have hunted for this video without success.
Do any of you know who did this interesting solution to the problem of stopping trains from taking a deep dive? I would like to give this approach a try, but I know nothing about Arduinos.
Thanks!
It doesn’t seem like an Arduino is necessary. A simple contact that actuates a Tortoise switch machine to raise and lower the pins would work. If you want to keep the contact as simple as possible it could control a DPDT relay to reverse the switch machines.
Mark Vinski
Arduinos are great! But in the application you describe, it sounds like the train would just crash into piano wires and keep on driving until the engine derails… better than a tumble to the floor, probably, but still going to do damage.
IMO if you’re using an Arduino for this job you should have sensors under the track about a foot away from the gap. If a train approaches the gap when the bridge is removed, the Arduino cuts power to the track. And maybe lowers a barrier too, for good measure.
If you have keep-alives though, your Arduino would need to send a DCC emergency stop command before cutting power; also doable, just a little bit more work.
If you’re interested in jobs like this I encourage you to get into the Arduino! But you’d have to start with something a lot simpler, like LED signals or whatever, to get your feet wet. This project is beyond the scope of a complete beginner.
if the goal is to prevent accidents, you could drill a hole and drop a nail into it to block cars.
Mine was a swing up section across a doorway in the middle of a 10 foot block. I simply used a door bell button to remove one rail of the track power to the block with the bridge up. With the bridge down and in place a bracket on the bridge pushed in the door bell button to restore power to the block.
That worked great from 1951 to 1958, I never had a problem and it was totally automatic operation.
Mel
My Model Railroad
Bakersfield, California
Being totaly sarcastic because the electronics are taking over everything why not an IBM mainframe computer? That way big brother can monitor what trains you run and either collect more data on you or shut you down completely. A microswitch that the bridge activates when in place can shut the power off to a big enough section that everything comes to a halt way before the big chasm.
And if you want to use an Arduino, drill a hole through it’s circuit board and run the nail through it into the track. That’ll stop anything.
