Hello All,
I run both Atlas Remote Switch Machines (#52 & 53) and PECO PL-11 Side Mounted Turnout Motors.
Both are dual solenoid type turnout motors with three wires feeding them.
On my pike, both these types of turnout motors are activated by Atlas #56 switch control boxes and PECO Capacitor Discharge Units.
One thing to note on the PECO PL-11s is the color-coding.
Even though the wires on the PECO units are the same color as the Atlas; Black, Red, Green.
The polarity is very different.
On the Atlas units; according to the schematics on the packaging, the Red and Green wires are the actuating power- -outside poles, and Black is the “Neutral”- -center pole.
On the PECO units, the Black and Red wires are the actuating power and the Green is the “Neutral”.
Because these are both solenoid type switches only a single pulse is necessary to activate or “throw” the turnouts.
A “momentary” pushbutton or switch is required not an “On-Off-On” SPDT.
If you use a non-momentary switch and don’t return the switch to the “Off” position immediately you can burn out the solenoid from the constant current to the solenoid.
Capacitive Discharge Units (CDUs) provide this momentary pulse and can only be “fired” once per switch activation.
If you don’t use momentary switches only one pulse from the CDU will reach the solenoid, no matter the delay in moving the switch to the “Off” position.
Another advantage of a CDU is the increase of amperage per pulse.
With two PECO PL-11s in series, this extra “oomph” is enough to throw both turnout motors simultaneously.
Hope this helps.
Post Script: I have kept the Atlas color-coding and change the PECO coding at the end of the wiring harness from the PL-11.
If you only use a few Atlas Remote Switch Machines you can easily switch the co
