If you know you’re eventually going to go DCC anyway, might as well quit putting money into DC that won’t take you where you want to go.
If you’ve decided that DCC wilkl never blight your layout, like me, probably, then you should look at how the various control units work, and therefore, which one will work better for YOU.
The Quantum Engineer has a microprocessor controlled relay in it. That’s a DPDT switch with a tiny computer flipping it back and forth. When you activate your horn using the opower pack, you flip the direction switch, right?
The QSI unit does exacly the same thing, very very fast. They have like 20 or 30 back and forth flips programmed into that thing, and it will do what your direction control will do, only MUCH easier, to the point where you use the sounds much more frequently than you will with just the direction switch on the power pack.
I do NOT have facts to back this up, but I believe that the MRC Black Box actually takes a DC input and creates a DCC compliant output signal out of thin air and electronic miracles. I say this because MRC explicitly forbids having this unit inline while operating straight DC locomotives.
Now, the Quantum Engineer will ruin a DC locomotive’s day if you try to blow the horn while dragging a long freight, and your’s too when it all hits the floor, but as long as you don’t push the buttons on the QE, the straight DC trains run FINE with the QE hooked uip, as long as you leave it alone.
But the MRC unit says you have to disconnect it. My LHS guy, who is 8747435623424372387276 years old and knows EVERYTHING about model railroading has no idea how the Black Box works, but, through elimination, we have figured out some things it probably can’t do, leaving only a few options how it can do what it does do, and we are so far convinced that it generates a DCC compliant signal or a near DCC compliant signal, and your DCC trains run in DCC mode on your “DC” track.
Well that raises so
