I’m creating a diorama and used cardboard webbing with a plaster cloth overlay that turned out looking like a large waffle. I then spread Sculptamold over that, which hid the waffle look but isn’t too smooth. I’m considering pouring a thin layer of Hydrocal over the Sculptamold so level and smooth out the overall look. I’ve read some previous posts and saw the suggestions of using Plaster of Paris since I already have the “hard shell” but I already have the Hydrocal and may as well use it. Can I just mix a small amount and lay that over the Sculptamold and continue until the whole landscape is covered? This is the first time I’ve done this and I don’t want to muck it too badly. Thanks for any help!
Unfortunately, the waffle look is caused by screwing up the first step of the process - the cardboard web. Chalk it up to experience and start over. Put the pieces of the web closer together and stretch the plaster cloth tighter. Some folks use masking tape or drywall tape (the plastic grid type) on top on the web to help prevent the waffle effect.
Since you have the Hydrocal on-hand, it sorta makes sense to use it. However, for my pace of doing such work, it hardens much too quickly.
I used Durabond 90 for all of my scenic landforms, applying it over aluminum window screen stapled to the open grid benchwork, with additional risers where necessary. The “90” in the name refers to the approximate setting time, in minutes, but it’s also available in 20 and 45 minute setting times.
All versions can be mixed to various viscosities, and will harden in approximately the specified setting time. Once hardened, it is very hard, and difficult to sand - not normally a requirement for scenery.
Here’s a partially finished area of my layout…
I originally tried to paint it with interior latex house paint, and while do-able, it was time consuming and labour intensive. Instead, I thinned the paint about 50% with water, and applied it as a stain - extremely fast and easy, and all of it will eventually be covered with other scenic materials, like this…
The resulting structure is also very strong, and in areas where the layout is deeper than usual, I can stand on a stepstool and reach in, supporting most of my weight with one hand directly on the landforms, in order to reach areas otherwise inaccessable.
I use Durabond to cast rock features in Woodland Scenics rubber moulds, and also use it to create water scenes…
The latter are all done atop well-supported 3/8" plywood, with the Durabond “worked” to create ripples and "
Everything mentioned above works very good and I did it the same as Wayne for over 50 years with great results. I started my current layout using the same technique as Wayne but I happened to run across a large quantity of 2” x 12” x 18” Styrofoam blocks. I used Styrofoam glue in the calk type dispensers and layered the blocks, some up to 34” high. I used a hotwire cutter to form a rough contour then used Plaster of Paris rock molds to make my mountains. The foam is very strong and extremely light, I used the same material for rolling hills too.
Here are a few pictures of my Styrofoam based scenery.
The picture above is adding the Plaster of Paris rock castings to the Styrofoam blocks. Messy working with drippy Plaster of Paris but looks so good when its finished.
while i no longer use hard shell( gone to shaped foam) , when i did i used 3/4 inch chicken wire as a base and old bed sheets dipped in hydrocal , resulting in a thin(at the most 1/16 or 3/32 of an inch thick) strong light weight and tough covering.
Plaster cloth usually ends up with a waffle like surface, and Scuplamold has fibers in it that can leave a rough surface. Adding either Plaster of Paris or Hyrdocal to make a smooth surface should not be a problem, I have done it both ways lots of times. I prefer Plaster of Paris because it is easier to drill into to plant trees or otherwise modify. Hydrocal dries rock hard, so it is hard to modify or carve.
Thanks for the input, Carl. As I said in my initial post, the Sculptamold has already been layered over the cardboard webbing and plaster cloth the the Sculptamold finish is rather rough, hence the need for the Hydrocal. If I ever do this sort of thing again, I’ll pay more attention to the webbing spacing to do away with the waffling. Thanks again.
I made the mistake of spacing the cardboard grid too far apart when I installed it. I did not know I could smooth the Scuptamold as I was installing it in the first place. I watched a lot of MR Video Plus to see how it’s done but didn’t see how smooth it was when finished. Oh well!
I don’t seem to know how to copy pictures in my quote, but your picture is there. 35 years ago, using hydrocal and paper towels that spacing gave me waffles.
These days using plaster roll, can you guys achieve a flat area, if you wanted the area above closest to the aisle to be flat for building placement, is that achievable?
You could probably do it using plaster, but most of my structures sit atop a suitably-sized piece of plywood, supported on risers attached to the open grid benchwork. The plaster-on-screen landforms are then added, with the screen also stapled to the edges of the plywood “building lot”.
For a town or street scene, I’d do most of the structures and their surroundings atop plywood, as you can always add lawns and other needed ground cover, along with trees, without having to use plaster.
My layout 35 years ago was cookie cutter plywood and I did not give any thought prior to construction for flat “buildable areas” I think I put sheets of cardboard on top my waffle and covered those with plaster.
Now I am working with foam, and flat is no problem. Creating postive and negative elevation is more challenging. Let me rephrase that, creating smooth positive and negative grades is more challenging.
