I got these PCB connectors on eBay with the idea I could use them to have a DCC decoder in my tender and use these to connect to the motor in the boiler. I’ve never used these before so I need some help.
Basic problem I’m trying to solve: use these to connect DCC decoder in tender to motor and headlight in boiler.
If I want to connect 4 wires from tender to boiler (2 for motor, 2 for headlight), how would I go about it? I’m assuming I would somehow cut 2 sets of 4 plugs from this strip. How do I cut off 4 plugs? With an Atlas saw or something?
Then I solder 4 wires from the tender to the back of 4 of these connectors, use the plug to connec to the holes to the 4 connectors in the boiler, solder 4 wires on the ends in the boiler to my motor and headlight?
I’ve been using them for years, they work GREAT!!!
I buy my connector strips off eBay, they are called header strips. There are two types of header strips, square pin and round pin. The round pin are compatible with the standard NMRA 8 pin DCC connectors. The square pin are compatible with Arduino connectors.
Both come in single row 40 pin and double row 80 pin male and female. They advertise them as breakable but that normally dings a pin at the break so I use a razor saw to cut the strips.
The connectors normally have a bevel (“V”) between each contact so you can use a single-edge razor blade or an X-acto blade (e.g. #17) to score the “V” on both sides and snap them apart. For a double-row connector I score all 4 sides.
I find a single-edge razor blade easier to control and rock it back 'n forth as I slow-ly cut into the bevel. And, after scoring the sides, I cut all the way through with the last cut using a razor blade (rather than snap it) because it gives me a better yield. I then finish up the cut ends with a small flat file to neaten them up.
Whatever length or matrix of contacts you use, make a matching pair. You will solder the wires to the pins of one connector and the wires to the sockets of the other connector. Then you slide the separate connectors together to make the connection.
IMPORTANT: Make sure you check your wiring ahead of time to assure that the correct wired sockets align with the correct wired pins. [Y]
For connecting the wires to the socket end, I pre-tin/prefill the sockets with solder and pre-tin each wire. (With the pre-tinned socket I like the solder to be level with the socket.) With a small amount of solder at the end of the soldering iron tip, I re-melt the solder in each socket then quickly slide its matching tinned wire into it; holding it still until the solder has cooled.
The key here is to be quick with the soldering iron; otherwise, you’ll melt the plastic connector. I use a beveled tip in my soldering iron and set the tip temperature to 700oF.
Soldering to the pins is much easier. I pre-tin the pins
I have a cutting mat on my workbench about 1/16” thick and put the header strip against the edge to sorta hold it then use my Atlas Snap Saw to cut the connector.
The single row connectors can be held with two pair of long nose pliers and bent to break them, if you hold the pliers very close together it won’t waist a pin. Bend to break them, if you hold the pliers very close together it won’t waist a pin. You have to use a razor saw to cut the double row strips.
As for wiring them I have a Panavise Jr to hold them for soldering the wires.
EDIT:
Tom, I now buy the male strips because the pin is slightly larger in diameter than the socket pin and they fit tighter into the socket. Probably the gold plating.
Mel
The one advantage that I can think of using both socket headers (vs a socket & a pin header) is the shorter profile, which can be important with decoder installations. And, while not as tight-fitting, there is enough friction-fit to the socket end and pin ends of a socket header to hold them together fairly well. This makes them easier to slide apart if I need a connnection to be more “disconnect-able” for dismantling purposes.
I got a bunch of those round machine pin headers a while ago with the intention of making plugs, but I found that after several times of plugging+unplugging, the connections become loose and unreliable. Do you guys have the same experience or did I get a bad batch of pin headers?
As a followup, what do you think is a good stratey to attach/expose the pins from the tender? Would you drill a hole or holes somewhere? Assume I have either 2 or 4 wires that need to get to the boiler. This is a small tender for a Mantua “big 6” shifter, but would probably apply for brass too. I don’t want to wreck the model with a a bad strategy.
I like installing my decoders in the boiler (either on top of the motor or underside roof of the boiler) to minimize the number of wires between the locomotive and the tender. The one exception to that is when there is a backup headlamp on the rear of the tender.
The photo that I posted earlier shows that connection. Here’s additonal photos showing it in more detail:
As pictured, I notched the front apron of the tender to accommodate each female socket. To minimize the notch I epoxied styrene to the brass underside then used a miniature flat file to cut the notch; testing the width frequently with the socket to ensure that it just fit into the notch. I then used Loctite Plastics Bonder (LPB) to adhere the socket to the styrene.
The LPB is a 2-part adhesive with a glue and an activator. You apply the activator first with the built-in pen applicator to each bonding surface and let dry. You then apply the glue to one of the surfaces. The LPB will give you a few seconds working time before it starts to grab hold. I always test fit everything first before applying the LPB. That way there are no surprises.
If you plan to install your decoder into the tender then you’ll probably need a minimum of a 2 x 3 or 6 x 1 connector to accommodate the + & - motor wires, + & - front headlamp wires, and the right rail wire. (I’m assuming the left rail wire can just pick-up from the tender wheels.) You could also have two 1 x 3s. Or, you could purchase a 6-pin mini-connector that dangles between
Yes I’ve had some problems using the female sockets for male connectors coming apart after a lot of disconnecting. That is why I went with the male header strips, the male to female stay together much better.
Mel
I mount my decoders in the tenders and mount the 8 pin female socket in locomotive. I use an 8 pin male on a short pig tale from the tenders to the locomotive.
Mel
Thanks for the helpful tips everyone. I’m trying to remotor and add DCC to an old Mantua “big-six?” to learn some skills. I don’t quite know what I’m doing yet, and I’m learning as I go, so advise from this group is very much appreciated! Lots of newbie and rookie mistakes at this point.
I replaced the open frame motor with an SE15 can motor. I want to try to put a decoder in the boiler and a speaker in the tender.
Question 1: How can I get the current from the motor frame to the right contact on the motor? It looks like solder is not going to stick to the motor frame or even the original brass motor frame that I repurposed to give me the angle for the worm. Do I I drill a hole in the frame, drive a screw in, apply solder that that screw, and run a wire from it to the motor lead?
Question 2:
This looks to be a 2-56 screw that holds the drawbar on. If I wanted to get more of these, I don’t know what name it goes by, with respect to the “washer” type head? What are these types of screws called?
Question 3:
I don’t have a picture handy, but I’m trying to find replacement “lug” connectors that Mantua used that was attached to the end of the tender wire to get current from the tender to the motor? It looks like a small piece of brass or steel that clamps to the wire and has a hole in it that you put a screw though, which screwed into the front truck hole in the tender? Where could I get replacements for those - I dont know what name they go by to search for them.
Edit: What is this called and where could I get replacements?
Question 4:
If I wanted to put a sound decoder in the boiler, w
I drill a #52 (1/16") hole in the frame and use a 2mm tap. You could use a 2-56 tap, since almost all model railroad stuff is manufactured in either China or Japan I use metric screws.
I use 2.2m solder lugs for chassis connections. All the electronic parts stores here in Bakersfield have closed so eBay is my goto.
Any recommendations on a good brand of #50 drill bit to drill into a Mantua frame? I tried this one but it doesnt do so well. Assuming slower RPM for drilling in this situation?
ESU makes a micro version of the Loksound 5 decoders and has a sound file for a Baldwin 0-6-0. Here’s the webpage link where you can find that. The TCS WOW101-Steam decoder is also very good - especially motor-control - but it doesn’t come in a small size and may be a bit long (1.35") to fit in the boiler.
The Tsunami2 is slightly over 1" in length so it might fit. The Loksound5 micro is only 0.82"L (x 0.39"W) and might make a better choice. Measuring your “free” space above the motor will dictate that. And the Loksound 5 have excellent motor control, too.
If you are going to install a decoder, you do NOT want to connect the power from the frame directly to the motor. Likewise, you do not want to connect power directly from the wheels to the motor. The power goes to the decoder red and black wires. Then the decoder is connected to the motor using the gray and orange wires. The motor must be completely isolated from direct track power. You may have to insulate the motor from the frame.
Once you have the decoder installed, if the locomotive runs in reverse when it should be going forward, you have two options. One is to reverse the orange and gray wires on the motor (preferable), or there is a CV that can be changed to correct the problem. If you just change the CV you will have to remember to do that each time the decoder is reset.
I use the pin connectors too. Here is one of my installations. It is very similar to what previous posters have done:
Note that I have colour coded one of the sockets so I know which way the plugs go in. The next time I do something like this I will reverse one of the sockets like Mel does. Then there is no chance of getting the plugs in backwards.
I also put a small dab of epoxy on the plug wires to reduce the chance of the wires breaking due to fatigue.
By the way, congratulations on doing your first decoder install!
These work real well in HO models, but with N scale I have found that the NEM 651 works well and it is much smaller. There are DCC supply stores that stock these in bulk 40 pin strips. You can cut to the length you need. These will also work in your HO models.
