I’m going to be using real tree sticks and bark(with white mold stuff on it) to give my scenery and more rustic look. Has anyone done this before? I’ll being using woodland scenic water and I’ve read that you should preserve the wood to prevent rot. I’ve read that epoxy resin helps in that. I’ve had them in the freezer for awhile to kill off any bugs but now I read that may cause mold once I take it out.
Any advice on how to handle using real wood would be great.
The “white mold stuff” is probably a fungus. Frseezing may kill it, but maybe not. It’s natural niche is breaking down wood, so it’s likely to find an environment that helps it grow unless your layout room air stays very dry.
Sounds like you want to embed at least some of the wood in “water.” Just make sure it’s dry and if it’s encased in any of them popular products and it’ll be fine with no further treatment.
The old trick was spray anything from trees or plants with hairspray to seal them. There might be a commercial sealer designed specifically for the job. I was lazy and didn’t seal any trigs or parts of bushes I used but after several years I haven’t had any problems except that some of the fine parts of a bush I used for trees in winter without leaves have broken off after become brittle. The twigs I have used as tree trunks have not had any problems. I live in the desert so the humidity is usually low so things don’t get moldy. There are not many insects which might want to eat them either.
The latest What’s Neat video from Ken Patterson starts with chopping up leaves to use as scenery material. He is uncharacteristically messy as he chops the leaves with water in a blender and dumps them on a screen before cooking them in an oven at 200 F.
Nice shots as always…I’m interested in the color of the deep water in the last two pic’s. Not so much the texture…just how You achieved the color. Looks to be a Grey/Blue in the pic’. Would You mind elaborating on that a bit? You can send Me a PM if You would. I’m usually pretty good at making up match colors, but having a hard time with making one like Yours for My river scene. Could be My eyes, I have Glucoma and shades of color just aren’t the same anymore to Me.
Just a reminder that if there is a concern about importing “living things” (flora or fauna) into your home with tree bark or sticks, freezing is not necessarily going to kill them; after all, we have plants and insects each spring after a harsh winter. Some time in a microwave is more likely to kill off any invaders.
BTW, I would be reluctant to introduce any form of mold into my home/basement.
The best use I ever saw of natural twigs and stuff was on a club layout up in Wenatchee. They had found a weed thingy that looked exactly like a dead fir tree. Which is pretty neat. And when some lucky volunteers applied green stuff on that armature, it looked exactly like a live fir tree. Even neater!
As a consequence, they had whole hillsides of exquisite forests. I am recalling hundreds of trees, here.
Thanks for the come-back. The color I would like to try and achieve, is the one in the 3rd pic’. I can see that lighting will make a differance in what the color will look like, I’m experiencing that now…My blue looks too blue in the light and black with the layout with the building and other structure lights on, which is ok…but I think it would look better with one of Your colors. It’s for a deep water river scene, where one end of layout connects to the larger part in the other room through the wall, which will eventually be mountainous. An area that I have put off for many yrs. completing. It was functional though for the double track mainline…just never finished the scenery.
Do You still have the same E-mail address? Mine is the same. I’ll just send You a PM with My address.
Thanks alot!
Take Care! [:D]
Frank
BTW: The Blue in the pic’ is sprayed on 1/16’’ poster board with clear embossed Acetate called ‘‘still water’’ that I found from a MFG. in Spain. The water is removable. Not glued down yet!
