How would operations work with that lumber facility? Flatcars arrive with lumber to get transported on trucks for customers? I saw pics of rail served lumber facilities with stacks of lumber.
Since I model the early 1980s, where to get centerbeam from that period (or earlier)? I see that places sell those cars with BLT dates from the 1990s. Should I just use bulkhead flatcars.
Can’t help with an of your questions except Canadian Canyons had a plywood mill and had the wood wrapped in plastic. I don’t remember where they got those.
Here is the kit in questionhttps://www.walthers.com/clayton-county-lumber-kit
Not sure what kind of lumber yard this kit represents. My kit was used for a warehouse ( I split the largest building in half and made a flat twice as long) and one of the other buildings got an end door and is now an engine house for my industrial “critters”. The last 2 buildings are probably going to be an agricultural warehouse. Most lumber yards i’m familiar with have one side open and intermal racks for different size boards.
I’m not familiar with the dates regarding centrebeam flatcars , but I’m sure that bulkhead flats would be acceptable for your modelling era.
At one time lumber was shipped on regular flatcars, in gondolas, and in boxcars, too, and since I’m modelling the late '30s, I’ve done loads for all three types of cars.
If there is, I wouldn’t mind hearing about it.
While at one time, many years ago, basswood was one of the few options for scratchbuilding, I pretty-much dropped it when styrene sheets, strips and shapes became readily available.
I had no use for my supply of stripwood, until I decide to make lumber loads, just to use it up, rather than tossing it in the woodstove…it wasn’t cheap, and nowadays, is even more expensive.
Here’s a lumber load built from it, which will fit only these Walthers’ models of 53’ GSC flatcars (I have a few, so don’t have to have it always showing up on the same car)…
…here’s how to save at least a little bit of your money…
This is an old Athearn 50’ flatcar, with bulkhead ends from those Walthers GSC cars, and its load fits only this type of car (and again, I have several)…
…and use the same ruse for the load…
This load, built from strip styrene, fits only these Walthers 50’ boxcars (I have quite a few of t
If you read the Product Information on the page that Henry linked to, you can make up your mind on how you want to use it.
I’m not 100% on this, but the center beams were introduced in the late 70’s. They were shorter cars, 60’ or so long, and most had the “opra” style openings in the centerbeam.
I believe in the early 80’s, the 73’ cars came out. You’d be good with just the flats, and if you find any of the older models, mixing in one or two would be right.
Not sure if you can get them anymore from the on line shops, but if you hunt Ebay, look for McKean models.
Looking at the buildings in the kit, you get a collection of small storage buildings. The one building looks like it has elevated doors that can be used as a dock for trucks or boxcars.
Or, if you want to unload flatcars, simply run the spur into an open area, with space on both sides to unload bundles of lumber off of flatcars using a forklift.
The unloaded lumber could be stored in the sheds or around the property in the open.
If your lumber yard receives boxcars (even today high-grade plywood, millwork and particle board/MDF that needs to be protected from the elements is shipped in double-door boxes) then you’ll want a ramp or dock for them to be spotted at.
There were some centerbeams in the late 1970s, mostly the shorter 60’ ones vs. the now-standard 73’ cars. They weren’t super common yet though, with only a few railroads owning relatively small numbers of them, so a lot of shipments would have been on standard flatcars and bulkhead flatcars. (Or boxcars.)
Flatcars and/or boxcars. The individual lumber units from the railcars would typically be moved onto storage racks or stacked atop one another until sold.
Bulkhead flats were common, but at that time so were plain flatcars. A few roads did have early center beam cars (including western roads like UP, WP and BN), models of which were made by ExactRail, although you may have to do some serious hunting for these now.
Good loads won’t necessarily be cheap or fast, but there are multiple options.
The above load is from Jaeger, and consists of wood blocks wrapped with a paper material. Kits could be had for numerous lumber companies, and they featured vinyl chart tape for banding (1/32" and 1/64" tape can be had separately from Amazon), and wood blocking.
This load is from the plastic kit by Wheels of Time. It includes blocking, but not banding material, so I used leftover tape from Jaeger kits. Most of the time spent on the Wheels of Time loads is in painting the plastic t
