I’m not an electrical engineer but have you thought about a reostat or VFD? I do know that AC motors lose a lot of torque running slower and heat up quite a bit unlike DC motors. My ceiling fans are on reostats so I can turn them way down. But they hum a lot and can be stopped easily.
Not an electrician, either. But I believe that it is basically like a light dimmer switch. If anyone you know has a sewing machine, the foot pedal they use to control the machine’s sewing speed is, I think, very similar.
If it helps, I’ve got one of those Ultimation sanders. Designed by a modeller for sanding wood and plastic.
Since is is not powered, you have infinite control. IIRC, the motivation to create this was someone building a wooden snow shed in O scale and needing a lot of accurate angles.
Basically like a light dimmer switch but important to note that a motor speed control is rated for a heavier draw - never use a light dimmer switch to control a motor.
I can’t imagine why a good motor speed control wouldn’t work in this situation just be aware of potential motor heat.
And, like others, I am not an electrician so take the advice for what it is worth…
The Shopsmith is just way too big. This would be only of only two bench-top tools in my house. I also have a smallish drill press. I just don’t have room for a real wordworking shop.
There could have been something wrong with my old one only letting it run 300 RPM. That I do not know. It was perfect for precisely sanding basswood sheets.
I do have a pedal from an old Pfaff sewing machine. Would that be usable as a speed control maybe?
A word of caution: single speed AC motors are usually induction motors. They are designed to run at ~3600 or ~1800 RPM. If you use a reostat or Variac to lower the speed the motor will try to maintain its speed and just draw more and more current until it overheats and destroys itself. As the TV commercials say, do not try this at home. Small variable speed motors are designed to do this and are either series wound or permanent magnet. Dremel tools and model train motors are examples. Larger variable speed tools such as drill presses or sanders use multiple pulleys to change speeds.
