Via Rail new equipment.
The Federal Government in Canada brought down a budget yesterday. Via Rail was given money to replace all its cars and locomotives in corridor service (between Windsor, Ont and Quebec City). The plan for dedicated passenger track between Montreal and Toronto is still under study.
http://m.viarail.ca/en/about-via-rail/fleet-renewal
Looks official. Maybe something will actually get done for once.
But new, fast trains are useless without fast, clear tracks to run on.
Thats good news they can standardize the hodge podge of equipment they have now in that corridor. Since Canada is offering to pay for a new bridge to Detroit. Any news on when VIA Rail will extend service to Detroit and add it to the Windsor Corridor?
Probably never. Detroit is slightly outside of VIA’s service area.
Didn’t they previously go there?
CN’s service into Detroit was from Chicago via GTW.
The CP did operate into Detroit through Windsor (and the engine crews changed in Windsor though the train crews went under the river into Detroit).
Right up until Amtrak……CN had a connecting bus to/from trains at Windsor that looped through downtown Detroit.
Prior to that…through cars (including sleepers) between Detroit and Toronto were ferried across the Detroit River from GTW’s Brush St Station and attached to trains at Windsor.
I saw no mention of a BUY CANADIAN requirement. Could Siemans (read Sacramento) be a bidder as well as Bombardier?
Bombardier does not currently have any suitable designs. I don’t know if they could design new trainsets and produce them by the proposed introduction date. The only North American designs available would be Siemens for locomotives and Talgo or Siemens for coaches. There would probably be some requirement that a certain percent of the manufacturing be done in Canada. Of course, it is possible another manufacturer would come up with new design, but it seems unlikely.
I would expect so. Siemens has a good track record of selling (light) rail equipment in Canada, dating back to the late 1970s when Edmonton bought their first U2 LRT cars.
I am not aware of any “buy Canadian” requirements in our laws, but Federal funding grants may come with their own unique strings attached. You never know, VIA did not have any trouble choosing the American-made GE P42’s over the Canadian-built EMD F59 when they needed more locomotives some years back.
From the specs stated in the VIA page I posted, the new trainsets will be bi-directional (second locomotive or cab car on the other end) with Tier 4 compliant dual-mode locomotives. This makes Bombardier’s ALP-45DP the obvious initial front-runner for motive power. While it was produced before Tier 4 came into force, the diesel engines it uses (CAT 3512c) have since been modified to meet that standard.
Other options could include dual-mode versions of the Charger, MP54 or F125.
I expect Talgo to be another bidder for the trainsets, in addition to Bombardier and Siemens.
The desire for electric propulsion indicates that VIA is not giving up on regaining access to the Mont-Royal Tunnel, so I also expect the new trainsets to be single-level.
The Bombardier locomotives were designed for commuter service which usually has a maximum speed of 70 mph or so. Presumably Via would require locos that are capable of at least 110 mph for their dedicated tracks. Can the Bombardier locos be upgraded to allow this?
I had assumed that the running gear of an ALP45DP was good for at least 110mph and perhaps higher. I will check when I can, as I think there are now two runs about to be produced for different customers and up-to-date information on effective speed (it’s higher on straight electric for prime-mover-related concerns) should be available more or less directly.
Thanks. It would be interesting to know.
Does it really cost less to purchase an entirely new fleet of cars? I would think the only change that needs to be added would be to make the LRC coaches push-pull compatible…and obviously building cab cars.
If Bombardier gets the bid, they could possibly revamp the desgin. They’re basically VIA’s version of the Amfleet. Sure they’re older, but they’re definitely reliable (and lighter too). I think it actually makes more sense just to take…however many of the Renaissance cars are still operating and rebuild them as LRC’s. They don’t need tilt to work well.
The problem with rebuilding cars is that it still leaves you with what at the core is still old equipment. Nothing lasts forever, not even steel centre sills. Even before this funding announcement VIA had revealed they plan to soon retire the ex-Amtrak stainless steel coaches.
The LRC coaches have been the backbone of VIA’s corridor fleet since they were built in the early 1980s, which will make them nearly 40 years old by the time their replacements arrive. While they are not nearly as old as the Amfleet (and nowhere near the Heritage stainless steel cars) they are significantly older than the Acela coaches (which are based on the LRC design) which Amtrak will be retiring around the same time. Perhaps the Bombardier LRC family simply does not age well (they don’t build 'em like they used to?).
The Renaissance cars were a maintenance nightmare (frozen plumbing, not handicap accessible) when first acquired, and they still have ongoing issues. Their availability rating is far lower than anything else VIA has, especially during the winter.
VIA has not stated that tilting will be a requirement of the new cars, but a properly working system (unlike the LRC) would be quite helpful.
Meanwhile the long-distance ex-CP stainless steel fleet rolls on, albeit fewer miles at slower speeds than the corridor fleet.
Quoting myself here, I forgot another potential bidder. Viewliners would look pretty good in VIA paint…
The ALP45-DPs probably aren’t a good option. Heavy, worse than expected fuel consumption, expensive to buy, and they wear out their prime movers quickly.
Are there any other dual-mode locomotives currently available?
I should have expected bad things from CAT locomotive engines. Could a different type of diesel be used instead? Of course that does not solve the weight issue.
Not in North America. Siemens is rumored to be working on a third rail Charger, but that won’t be helpful. I don’t doubt they could come up with a Sprinter/Charger hybrid if asked. Stadler has a Eurodual model in testing in Europe.
I doubt there is ‘that’ much more involved in making a Charger dual-mode capable ‘at the diesel output’
In my opinion the likeliest way to make a ‘third-rail-capable Charger’ is to arrange to filter, despike, etc. the third-rail feed, and then direct this to the DC link of the inverter transmission. A small amount of energy storage (somewhat akin to keep-alive in model railroading) might be installed to keep the locomotive from stalling at low speed on long gaps.
Similarly it should not be difficult to transform and then rectify 60Hz AC for this purpose. That should be easier than the Conrail ‘duel-mode lite’ experiment in the early '80s.
The Siemens battery supplier for the Chargers has only just started working with ‘commercial-grade’ lithium-chemistry batteries, which would likely be an enabling technology for a Charger ‘hybrid’. Reasonably certain that mosey of the advantage of the battery would be in regenerative/wayside storage and rapid release, e.g. For commuter service or routes with many checks and reaccelerations, rather than for sustained fast running. There are other chemistries (and other potential uses for sustained high-current generation on falling grades) that might be useful, but I doubt a reasonable long-term economic ‘case’ for these could be made without subsidy. KERS (flywheel storage) is likely only useful if you build something like the ALPS locomotive (which uses the ‘flywheel’ for much of its high performance).
