Video: How to wire a model railroad layout
Hello Andy,
Excellent video on track wiring.
Will there be a video done on how you build your own turnouts?
andy
great video great tip from a expert
Thanks Hank
How do you wire a reverse loop?
Hey thanks great video replaced all my wiring on my layout when I went to DCC and no more problems. Using these suitcase connectors made the job a snap and no more soldering from under the layout!
I found another use for these suitcase connectors. Outside low, repeat LOW voltage landscaping lights. If you have them you know the connectors on them do not work reliabily. I replaced all of mine with the brown suit case connectors and no more problems.
great video and tip
Hello Andy,
I’m just starting my layout.I need to know how to wire the layout.Thank you for the nice tips.
Hi Andy, well it’s that time and I’ll be using your wiring method. Only problem Im having so far is finding a source for the bare 22GA wire??
Can you suggest a source or maybe where you get it from.
Much Thanks
Greg
GREG you can get the wire u are looking for from MOUSER .com
Thanks for straight talk and illustrating how it’s done! One of the best videos on model rr wiring!.. Larry W
Great tips! I would love to have a how to from Andy on how he makes his turnouts!
How do you “drill” the hole using Music Wire? Is that the same as Piano Wire?
I bought a couple of pieces of Piano Wire, but as there are no Flutes to clear away the waste material, I’m lot 100% sure how this will work.
If the Music Wire that you are talking about is the one with a spiral wrap, I could see how that would work, as the wrap would act as flutes to remove the waste material.
Dio
Andy,
Good video, thanks. I’ve noticed that the pros at MR use suitcase connectors, my question is: do these electrical connections remain viable over time. There seems to be some disagreement as to long term connectivity integrity using suitcase type connectors as opposed to soldering. I am about to start wiring my Atlas #29 Central Midland layout and would not like to have electrical issues caused by inferior wire connections, or any other for that matter. Your thoughts. Thank you, Ed
Newbie of sorts here and I thought the video was highly informative. The cable ties are a great idea not only for neat organization but they also keep the wires in the connection from wiggling to prevent breakage. I had always heard never solder feeder wires to the inside of the rail but that might be significant in a smaller scale such as N.
Dio -
Since noone has replied I will take a stab at answering your question. A lot of folks refer to small hobbyist type drill bits as music wire (drill bits) such as these http://www.harborfreight.com/high-speed-steel-micro-drill-set-piece-61526.html OR http://www.micromark.com/SearchResult.aspx?deptIdFilter=0&searchPhrase=drill+bit [example - not a recommendation for purchase].
British Standard Wire Guage is decimal based as are guitar strings which lends to the confusion but alas, you can not drill through building materials with instrument wire. A chart you can print out can be found at http://www.imperialsupplies.com/pdf/I_DrillSizeDecimalEquivalent&TapDrillChart.pdf . American wire gauge (AWG) 22 is approx .65mm so you could use a #71 standard or .8mm wire drill bit. With a self-healing roadbed like cork you could try a 1/32" drill bit - YMMV. Hope this helps.
– Bob
Great convention coverage - made me wish I had been there.
I would really like to see a how to on hand laying track specify hand laying turnouts with out jigs. Since Andy has done if maybe he would be willing to show us in detail
