Hello All,
Answering a few questions will aid the great folks on these forums assist you in realizing your goal.
What scale are you considering?
By
Are you referring to an office space in your home, or will you be contacting H.R. and building engineering?
What size/shape of the room are you dealing with?
If this is a home office is there closet space available?
Even with the lightest weight materials, a 5’X9’ pike is still a weighty proposition (pun intended).
Years ago there was a thread on these forums about building an N-scale pike in a roll-top desk.
My reply was this could be done by having half the pike fold up and in the desk portion- -think reverse trundle bed.
The center pull-out drawer could support the “leaf” and the drawers on the side could provide storage for motive power and rolling stock.
Electronic components: booster, power strip, et al, could be mounted under the desk in the knee space.
In my house, “She who must be obeyed” has decreed that I can only use the space on the top of the bed in the computer/spare bedroom/train room. The pike sits directly on the mattress with previously no under pike access.
The B.S.&P. R.R. II is still a 4’X8’ pike but I reworked the frame from 5/8-inch Medium Density Fiber Board to an open frame with 1/4-inch plywood. Reducing the weight considerably.
Now, after clearing the pike of motive power, rolling stock, and the booster, I have devised a system of pulleys and hardware to securely suspend the pike over the bed.
To “camouflage” the underside a fitted sheet is attached to the underside of the new framework- -like a canopy bed.
If you are considering a fold-down pike- -like a Murphy Bed- -the height of the extended platform would be quite low to the floor, if you are pulling down the 9-foot side, unless yo
