Hello all,
After a few months of searching and getting out bid on e-bay. Finally,I won a coal floodloader.
The problem is,once I opened the box to see if all the parts are there. I soon discovered that the color of the structure is different,than the kit in the box. What color of blue ,is the structure on the picture link below ?
http://www.walthers.com/exec/productinfo/933-3051
Patrick
Might want to try some D&H blue. If you have to buy the paint, get something darker than you want it to be. You can always add a little white to lighten it up.
I was disappointed too when I found the cream colored sheet metal. I painted mine in SP Lettering Gray. Then I weathered the lower half of the steel work with black.
Thanks onetrack64, I knew someone would come through…thanks again.
Patrick
