Walthers DCC Turntables vs non-DCC
With Walthers DCC TT soon to arrive… What are the benefits for a DCC layout? Can the non-DCC be used? How much special wiring (if any) would be required. Thanks
The only difference between the DCC and non DCC version is that the DCC version allows you to control the spin via DCC. Both will work equally well on a DCC layout as far as power to the turntable bridge, there is no difference there.
I have a non DCC controlled Walthers 90ft. turntable. Works great with an AR1 reverser and an MRC power pack.
With the introduction of the DCC version, Walthers now produces 5 different turntables in HO scale.
The original version was a motorized 90’ turntable. It consisted of a manual turntable and an add on motor kit. I have that version, and it is OK, but I long ago abandoned the motor and simply turn it manually.
The next version was a non-DCC turntable with indexing capabilities. It was available in the 90’ and 130’ turntable. I have the 130’ turntable which I really like. I disabled the indexing feature and manually operate the stops by merely holding down the button on the control box. Although it is considered non-DCC, it is designed to operate on a DCC layout and that is the way my layout is powered. Wiring is simple, just two wires to the turntable and two wires to the AC terminals on a power pack.
The newest version is a DCC turntable with indexing capabilities available in both a 90’ and a 130’ turntable. Since these new DCC turntables replace the older non-DCC turntables, unless you can find the older version on eBay or some similar source, you will have to purchase the DCC version. Personally, I see no real advantage to the DCC version. With it, you can use your throttle to operate the indexing feature but, as I say, I have disabled the feature and just operate in manually. I haven’t seen a wiring diagram, but I presume that it is as simple as the non-DCC version.
I also have the non-DCC version (130’) and have a DCC layout; no problems. As others have already mentioned, controlling the rotation with a DCC throttle is the only difference and I also don’t see a need for it. I have a control panel for the turntable and it is located directly in front of the turntable, where you would want to be at that moment. See the photo attached (note;that is a dust cover on the turntable!)
-Bob
This is some great info on this topic. Has anyone had any experience with the N-Scale version of the Walthers non-DCC TT?
Built-up versions work great. Kit versions seem to be a nightmare and most are eventually discarded.
Sorry if this is a dumb question … but does this apply to the Walthers N-Scale 120’ TT (Item 933-3203)?
So far as I know, that was only available as a kit and is reported to be difficult to make work reliably. The 130’ built-up, by contrast, seems to work very well.
Walthers did produce a manual 120’ turntable in N scale and offered a motorized kit for it. The motorized kit was not the same one as used with the 90’ turntable in HO scale. So, whether the manual 120’ turntable in N scale suffered from the same problems as the 90’ turntable in HO scale is a question that only someone with the 120’ turntable in N scale can answer.
