i bought 3 of walthers’ undecorated GP15-1’s (inertial air filters) and all three the cab sits loosely on the body. can i glue the cab to the body with a few tiny drops of glue and still be able to remove the shell when needed to lube the gears?
yes you can. you can use a drop or two of CA such as Super Jet. after you’ve glued the cab you can still remove the body shell.
