I’m looking for the tire to tire dimension (on center) as well as the outside frame to outside frame dimension. (across the rails) This would be in N scale. The Walthers book and website only list overall dimensions and I would like better numbers if possible. All the LHS are out of stock at this time so any help would be great.
Guy
guy have you tried a google search for Mi-jack? or even went to an intermodal yard?
i think there are several in the minneapolis/st paul area, if you do go to one call before hand to make sure it is alright for you to be there and get the name of the person you talked to.
if that fails they may be able to direct you to a source of information into what your looking for
hope this helps
tom
