Can someone tell me the length of the Walthers Shinohara #6 double slip?
Also, I am not sure I understand the complete routing options on a double slip. Looking at the double slip, there are two tracks on the left and two tracks on the right. (I realize that there are only two tracks that make up the double slip but to simplify my question, let me refer to the double slip as two left tracks and two right tracks).
I understand that one route is from upper left to lower right (or lower right to upper left) and a second route is from lower left to upper right (or upper right to lower left).
But, can a third route be from lower left to lower right (or lower right to lower left)?
And a fourth route from upper left to upper right (or upper right to upper left)?
Thanks for those dimensions. Good question on Code 100 versus Code 83. Code 100 is what I am looking for, but I didn’t realize that the two different Codes would have different dimensions.
Shouldn’t be much difference for rail code, but the higher the turnout number the shllower the angle so the whole thing will get longer as teh frog number gets higher. There’s nothign inherent in the rail code that would make a Code 100 #6 any bigger or smaller than a Code 83 #6.
Despite all the combinations, there really are only two settings for a double crossover - either both routes cross over, or both routes go straight. That’s why, with a bit of linkage, you can get away with only 1 switch motor to operate it all.
True for a double crossover, but not true for a double slip. In a double slip, a train entering from any rail connection at one end can exit through either of the rail connections at the opposite end. This requires independently-controlled point throw mechanisms, one for each end.
The schematic equivalent is two conventional turnouts laid point-to-point. The double slip accomplishes the same thing in half the length, without S curves.
Chuck (Modeling Central Japan in September, 1964 - including hand-laid double slips)
I believe we are talking about different aspects of the operation of a double slip. Yes, there are only two crossbars; therefore, two motors or manual throws. However, to execute all 4 possible routes, you have to execute 4 different settings.
