my older turntable modle 933-2840 has worked very well until this morning no when i power up the layout i get a flashing power light on the controller i checked the power input on the controller and it is the 15 volts ac as allways any help would be very helpfull thank you phil
Clean the rings and tines under the bridge, that causes mine to do the flash dance. If that doesn’t work I’ll let the experts here offer help. Good luck.
i did try this and no differance thank you
Might need to reprogram, flashing light is what happenes at startup but goes solid after a few seconds. Wth power off push set and zero and hold and then turn power on and after about 5 sec, it should turn solid.
