Water color
I was just looking over one of the previous threads on “pourable” water. I picked up some Envirotex Lite for modeling a small section on my layout that will have three circular culvert pipes discharging into a concrete lined channel. My double track main will run over the top of this.
The only real life scenario I can think of is the Los Angeles River, tho I know there are plenty of other lined channels out there. The LA River is usually pretty dry - or even completely dry, but I’m not wanting to model that. I would have the channel holding water on the layout.
I have some acrylic paints as well as Quikcrete concrete patch that I’m thinking I will use to form and lay the “concrete” channel. I’m wondering about color:
In most pictures I’ve seen the water running thru a concrete channel looks anything but clear. I figured I would need to add some drop of color to the Envirotex when its poured. But then I wondered if it would actually look better to leave the Envirotex clear and simply brush on some browns and greens (under the resin) to give the appearance of times of lower water when perpetually moist concrete starts to stain and grows moss or algae.
I’m just soliciting opinions here: is it better to tint the entire mixture or to just paint the Quikcrete underneath and let that suffice?
I’m leaning towards the former not the latter.
In these pictures for example, you can see that the river is shallow, yet there are greens and browns underneath. How to best replicate this? Again, I will have a deeper river than in these photos with no bare concrete channel showing.
I would do both. First I’d paint the concrete, then I would add a drop or two of brown pigment to your resin. Not a lot. That water looks pretty clear.
Of course, you are not modeling the LA River so you may want the water more stained.
I’d guess that you could get decent results with either or with both. While I’ve used pourable “water” in the past, I prefer using Durabond patching plaster for the “water”, and painted-on colours (and a clear finish) for the type of water that I’m trying to represent…
I used Envirotex Lite for the Chicago River on my layout. So, the river runs through an urban enviroment. I painted the plywood base before pouring the Envirotex Lite.
I did some sample tests first and then decided to add a few drops of color to the Envirotex Lite before making the actual pour.
For color: do I need something special or will a drop or two of acrylic paint work fine in envirotex?
I poured Envirotex Lite over a large area, 12’ x 30", but I only used a few drops of paint into the mix. If you use too much paint, it will look like you just poured paint, so it takes ever so little paint in the mix.
My pour added up to 5 quarts of Envirotex Lite mix but, again, very few drops of paint. I will look for my notes to find out how many drops I used.
The photos below show the painted base before the pour and the same scene after the pour.
Wow that looks great. (Same for Docs pics using a different method.) And I think it perfectly illustrates original question. It almost looks as if you could have gotten away without tinting the resin at all and the greenish paint underneath would just show thru.
Edit: actually, your river color reminds me a little of my time living downtown in the west loop. Every St. Patty’s Day the river was especially green [;)]
That looks good Rich.
-Kevin
I always advise tinting with just a couple of drops of acrylic craft paints in a batch approaching half a liter. More volume, add a couple of drops per half-liter of the eposy. I would never pour more than enough at a single pour to cover the surface more than about 1/8-1/4" deep. You can correct as you go, mix another batch, and pour it over the cured previous pour.
I also add Plaster of Paris powder to create turbitidy, just a pinch between thumb and forefinger, maybe 1/4 tsp.
I use Hauser Green and yellow to create the look of the greenish/grey river near my home town in south central British Columbia.
The pour will be like glass on its surface, but only if you cover it well and don’t let anything touch it, or airborne solids land on it. If you’d like a more realistic appearance, spread a thin layer of gloss medium, like Mod Podge, over the cured top surface and then stipple it with the side of the applicator foam or brush.
Here is what my ‘river’ looks like outdoors on my diorama: [click on the image below for an expanded view]
Thanks, Andy. I wish that I had taken photos of the samples that I poured to show the effect without tinting the Envirotex Lite. It looked OK, but not nearly as good as when I tinted the mix.
That looks absolutely great. [Y]
Thanks, Kevin. It took 5 quarts of mix to cover a 12’ x 30" area. It was nerve wracking to say the least to work quickly over such a large area.
Great looking results, Rich, and likewise for your scene, Selector.[tup][tup][tup]
Thanks Wayne, much appreciated. I was prettty pleased with the overall results.
Thanks, gentlemen. It seems, from all the examples, that there really is no one way to do pretty much anything in the hobby. Just some imagination, some good materials, and a willingness to try something, refine it, and if it’s still a bust…well…you know…Plan B.
Different ways of doing waterbodies. I made about four small lakes on my layout to replicate southern VA. Initially, I was worried that the water looked like an industrial accident with various shades of a toned down slime green. I looked at actual lakes and many are that murky color.
I also believe in both base painting and tinting. I generally carve my water features from the sheet of pink foam. Then, I cover the cut up foam with plaster cloth to smooth it. I paint the plaster cloth base with washes of acrylic craft paint.
I usually do several thin points of Envirotex. I don’t have large areas to cover, so a couple of ounces suffices. I add a drop or two of acrylic craft paint to each batch. I vary the tinting from darker to lighter as I first pour the lowest layer. The darker tinting, not very dark, really, gives the deeper water a more murky look while the shallow water is almost clear.
I am interpreting this to mean that you did the mix and pour all at once. If that’s correct did you use their calculator to determine how much was needed?
Rick
I did use the Envirotex Lite calculator which indicated that I would need 5 quarts of mix. So, I purchased a 1 gallon kit (1/2 gallon of each part of the mix) and a 1 quart kit (16 ounces of each part of the mix).
I began with the 1 gallon kit. Following the instructions, I mixed the two parts together for 2 minutes and then completed the pour. That left me with 20 to 30 minutes working time.
So, I then mixed the two parts of the 1 quart kit for 2 minutes and poured that mix so that it merged with, and blended in with, the previously poured 1 gallon mix.
That left me with sufficient time to complete a satisfactory spread of the 5 quarts of mix, including the removal of air bubbles. I barely had any leftover mix from that 1 quart pour, so the Envirotex Lite calculator was dead on.
The area was pretty large, so it took two photos to capture the entire pour.
Good to know. Thanks.
Rick
