water effects flatten out and disappear
After (finally) achieving success in pouring a creek using Magic Water and letting it cure for 72 hours or so, I added some ripples and rapids with Woodland Scenics Water Effects as seen in David Popp’s series on the Thin Branch. By the next day, however, the ripples and rapids have all but disappeared, flattened out and transparent to the point of invisibility. Any idea how this happened and how to overcome it?
Having used Woodland Scenics Water Effects I can say that the stuff is both thick and stiff and flattens out hardly at all after curing, but was used on top of Envirotex epoxy that had cured for several days. I have no experience with Magic Water, but can only guess that maybe it wasn’t completely cured and that somehow effected the water effects?
Regards, Peter
Sounds a little like Modge-Podge, which some recommend. Keep applying and it’ll eventually build up…maybe.
I found something that works well in a single application, silicone cake decoration molding compound. It’s food grade, so not nasty like some silicone is to work with. It’s clear, but you can add whatever color you want, so easy to make whitewater.
A couple of the creek effects.
Some additional effects going on with Cascade Falls, but did use some of it here:
I’ve used a lot of both products and you didn’t do anything wrong! Magic Water is fully cured in 48 hours. WS water products are not my favorite.
To make water falls I layout the Water Effects on wax paper and let it setup for several hours then remove the wax paper backing and it will hold it’s shape. I have never had good luck with WS Water Products because they have always deteriorated over time.
All clear silicones turn cruddy over time and don’t even come close to looking like water. WS Water Products are the same as silicones as far as my experience goes. Over the last few years the only water looking products that haven’t failed the test of time are clear epoxies.
I have successfully rippled clear Epoxy but there is a definite learning curve t
erosebud, I have used Magic Water and WS water effects and have not had any of the bad results you experienced. I used a paint brush and stippled the WS effects on the Magic Water and the ripples stayed exactly the same dry as when they were wet. My streams are going on 8 yrs. old.
I use the old-style casting resin, the kind that comes in the blue-label can with a small sidebar of catalyst (can’t find my last can right now and the name escapes me.) Get it at Michael’s or Hobby Lobby, etc. It’s the stuff they make the clear cast paperweights out of with insects, etc stuck inside them. Not cheap (about $30/can) and stinks pretty well for a few days (consider your roommates’ reaction before starting [;)] ) but the stuff holds up well.
The pick below is of the Animas River crossing below Silverton. It’s sometimes called the “$50 River” because it took two cans to finish it when done about 20 years ago. It’s as nice as the day it was finished, although looks a little dusty in this pic.
Note that you can do nice, deep water and easily embed all sorts of 3-D stuff in it, like the deadwood piled up against the upstream side of the protection around the pilings.
I tried to use the Woodland Scenics Realistic Water product on an open-top water tank project several years ago and it has taken most of that time to fully cure (if it is indeed finally cured). I mixed it per the letter of the instructions and poured it no more than 1/8" thick but it never fully hardened. Yes, the surface became completely dry to the touch and the pour seemed hard in a day or two with a nice glossy surface. However, I wasn’t comfortable with the curing time and so I put the project on hold. Months later, I discovered that the WS water had actually absorbed the dust that had fallen into the tank, totally killing the glossy surface. Several months after that, I discovered that a figure had fallen off an adjacent structure into the tank. By the time I finally discovered the missing figure, it had partially sunk into the seemingly hard WS water leaving a large dent in the surface. You’d almost swear that this stuff comes back to life whenever anything touches it (Beware the Blob!). I won’t use this product again. All water projects since have used Mod Podge Gloss Medium with great results.
After skimming thru the Woodland Scenics FAQ concerning Realistic Water, it’s like Realistic Water really wasn’t ready for prime-time.
This may be of interest to the above poster:
Envirotex [Lite] sounds better and better everyday - just don’t go into the layout room for a few days after pouring without a gas mask…
Thanks chutton01!!! Your quote explains a lot. I wouldn’t call dust particles “placed items” yet they stick to Realistic Water as well as anything.
