Water Towers aren't just for locomotives
From the RYPN forum (which I am blatantly plagarizing here), this is too beautiful to not share here:
http://www.rypn.org/forums/viewtopic.php?f=1&t=42228&sid=12e378ed97fd40047cbe54d1799b3322
You’re right 'Dude, too beautiful not to share, both the steam cars and “you know what!”
Some more photos and videos for those interested:
https://lancasteronline.com/news/local/stanley-steam-automobiles-roll-into-strasburg-rail-road-video-and/article_40ed0578-85df-11e8-bd07-cfa946ca2354.html
Yes, I’m interested! Thank you both. I was born and raised just five miles from Tom Marshall’s estate. My mother told me about a little steam train he had and would open up his estate for visitors to ride on it, but only once a year. Never seemed to work out for me to see it. In the seventies, while I was working nearby at Hockessin Supply Co. I became acquainted with Tom. He seemed like a quiet, gentle sort of person and even looked like someone from the past by wearing “granny” type glasses. Once he brought a Stanley Steamer that I think resembled the mountain car in one of your pictures, but with the canvas top up as it was a drizzly afternoon. The Wilmington & Western had brought up their steam train and stopped right beside one of our warehouses, with Tom’s car parked in front of the fire company. I went over to take a picture of the car thinking it was shut off. Tom got in and just that quick drove off. That was a shock! It hadn’t made a single sound until it moved.
What is the operating steam pressures ? Do some owners do hydrostatic tests as well ?
Stanleys are all well and good, but have a look at the Doble- the ultimate steam car. Jay’s was owned by Howard Hughes. I once crawled under one at a show in Michigan- it was something!
https://www.youtube.com/watch?v=rUg_ukBwsyo&t=40s
If I remember correctly, Bill Lear (of Learjet fame) took a crack at a steam car design around 1970 or so. Nothing came of it, though.
A fundamental early design mistake (in my opinion) was his choice of an ORC (organic Rankine cycle) using a material other than water for the heat exchange – his was a set of “proprietary” formulas he called ‘Learium’ (and we called, predictably, ‘delearium’). Think of all the usual reasons the air around steam power is somewhat moist and hot, and then imagine you have something akin to a Freon instead (study the history of the power-station mercury turbine for alarming parallels) and when it has leaked out of your power loop you have to go back and pay for a working-fluid recharge before you can move.
Thermodynamics not really calculated properly, either. But I digress. You can read all you probably want to know about this on the SACA ‘phorum’, including where all the development equipment went after Lear gave up the effort.
If I remember correctly Stanley Steamers operated at around 400 or
600psi. Here is a link to some technical info: http://www.stanleymotorcarriage.com/GeneralTechnical/GeneralTechnical.htm
Don’t know about hydrotesting on a regualr basis.
More on Stanley boilers: http://www.stanleymotorcarriage.com/Parts/Boiler.htm
I get the impression from the link that the operator of a Stanley Steamer had to perform the functions of driver, locomotive engineer and fireman all at the same time. That kind of complexity would have doomed the steam automobile as designed despite the wishful thinking of the website owner.
But don’t forget that contemporary internal-combustion cars required fiddling with manual spark advance as well as throttle, choke, gearing, and the vicissitudes of several kinds of brake. And they stall easily, jerk, and have trouble, either pulling or stopped, on hills – all of which are trivial issues for any steam car.
Any modern steam car burned gasolene or some equivalent, and these burners would not require much adjustment to stay ‘blue’ during a run; water was not something difficult to keep adjusted, and Stanley boiler construction was notoriously insensitive to low-water problems (Doble monotubes for a different set of reasons) – if I recall correctly a good Stanley or White was less complicated to drive than a contemporary car of equivalent capacity and performance.
A more likely dooming involved issues with which there are modern equivalents. The need to find feedwater at relatively frequent intervals was a simpler issue in the days of horse troughs and unsophisticated boiler metallurgy; using the right water for sophisticated condensing rigs would involve the same kind of perception of additional expense as DEF/‘blue diesel’ in modern compression-ignition cars. In the days of F-head engines and low compression the fuel economy could be reasonably close for high capacity vehicles … does not take too much R&D before the understood thermodynamic cycle advantages of gas engines make internal-combustion motors FAR more fuel-efficient than the usual range of cost-effective external-combustion plants. (You may note that the ZEE, which I have always thought represented about the peak efficiency possible from a small Rankine-cycle plant, was never even fully developed as an automotive alternative powerplant even thou
