[#welcome] to the Model Railroader Forums, Coa!
I think that the previous responses have covered the subject fairly well.
However, I have found a few things that may prove useful.
Use distilled water for soaking the decal - itâs available in gallon jugs at any supermarket, and not at all expensive. This eliminates any dissolved minerals which might otherwise be present in tap water, and a gallon will do a lot of decals.
When youâre cutting the lettering from the decal sheet, use a sharp blade and donât cut to closely to the lettering or image. Once the lettering is free of the main sheet, place it on a hard surface (I prefer a sheet of glass), and use a sharp blade to trim as closely as possible to the image or letter, using a straight-down chopping motion. If necessary, do this work under magnification (eyeglasses, Optivisor, or loupe).
The reason for the two-part cutting is that slicing the image, even with a sharp blade, raises the edges along the cut line, and when you apply that decal to the model, the setting solution is often insufficient to to make those edges settle competely flat onto the surface.
The chopping motion pushes the edges of the cut down, making the applied decal easier to set.
Before applying decals, spray (I prefer Testors Glosscote, thinned with lacquer thinner and applied with an airbrush, but itâs also available in a spray can) the entire area which is to be lettered, not just the particular areas where the lettering will be applied.
Allow that to dry completely, usually at least a full day, and longer wonât hurt.
Do not rush the soaking process for the decal, but allow it to release from the backing paper on its own. If itâs big enough to handle with tweezers (not something small, such as a single digit for dimensional data), dip the released film into water, submerging it completely, then, as you withdraw it from the water, drag the back-side of it over t
