I have a Walther’s 90ft turntable that I’d like to do some weathering to before I assemble it. This would be primarily of the ‘cement’ pit itself. I’d prefer NOT to use any kind of powder for fear of it getting into the gearing in the pivot point itself or in the gear ‘track’ that goes around the inside perimeter. I’m going to give the pit a washing and then several light coats of cement colored spray paint as a base coat. I’d like to show some grime and oil mostly in the bottom, plus some rust stains on the pit’s sides. What should I use to do this and how is the best way to do it in your opinion? Any suggestions much appreciated since I’ve not done much in the way of weathering up until now.
What scale?
What are you turning on it, steam, diesel or both?
2A. How old is the pit?
Use acrylic paints that you can get from art shops. These are water based. For thick gooey stuff you can also get water based oil paints.
Sounds good. If you hunt back through my posts I’ve done tons of stuff on the colour of concrete, joints, cracks and stains.
If the pit is old it could have cracks across the floor. Dirt might have formed slands in puddles… non of which needs to be powder when you model it… build up layers of gooey paint to make the dirt/mud and (very gently/sparingly) pour in whatever you normally use for water/puddles… whether you paint the “concrete” of the base black first or introduce layer(s) of black in the “water” is up to you and some experimenting first… hopefully you can end up with an oily puddle… the real clever thing will be to get the rainbow effect that oil on water can have [:-,]
Wet or dry an old pit may have some plants starting (even really sprouting) in any cracks… both in the walls and floor.
Thanks Dave for the information. I’m in HO scale and the pit is used by a smallish railroad in the southeast US… not a lot of money if you know what I mean. The pit has been around a good while and now serves both late steam and early diesel. As far as the rust on the sides of the pit, that would be from where metal was left nearby over the years and some rusty water washed into the pit. Not much, just a spot here or there. Also, as you said, from rebar.
Thanks for the help and the suggestions.
JaRRell
[quote user=“Dave-the-Train”]
[quote user=“jacon12”]
What scale?
Glad to help… worth it to notice the signature you’ve added at the end of your posts [(-D]
I like the logic as well. [^]. If that metal included 40 gallon drums that were open or didn’t have a bung in the end some nasty, oily goo may have washed out as well as rainwater seeped in and overflowed them. may even have happened recently… soil or sand put down to make the surface less slick and stop people walking round the pit from getting all oiled up and even skidding over.
You got nettles and/or brambles growing in this junk pile? And a cat with a litter of ferile kittens…
Chalks can be usede to weather with great effect. If you don’t like how it comes out, just wash it off and start over. You can then seal them it dullcoat. Thin as paint and won’t gum up the works! Cheap too!
Jarrell, all the best weathering I have done was with slightly diluted acrylic craft paints using the dry brush technique. As a last coat to simulate rust pooled on flanges or ledges, us a light wash once or twice.
Thanks Crandell, I’ll refresh my memory on dry brushing. If I remember right though, it’s getting most of the paint off the brush by wiping on a cloth, paper etc. before working on the piece with it.
Yes, that is is. Go overboard on getting the brush free of paint the first time, and then pain a left-over piece of model styrene to see the effect…or use a junker box car. I think most of us don’t remove enough of the paint. You can always add more later, and the experts will say let it dry first to see what it will look like, and then add another layer.
I must admit, though, that I have had great success with washes. Say a drop of the paint squeezed out of the small plastic bottle, and then about three times as much water added. Mix, and then use a small brush tip to wipe up the side of a flange on a girder or something. I’ll dip a toothpick a couple of times in Burnt Umber, use the toothpick to take half a drop from Red, and then about the same as the Red in plain Yellow. Mix, add a full tsp of water, mix, and use a fine brush to splash flanges, ledges, rivet row, etc. I’m pretty sure the TT bridge was done that way. Experiment, as I did, and you will develop some magic…if I can, you are sure to be a full Wizard!
Check my posts for dry brushing technique… um [%-)] can’t find it quickly. There’s ;ots of ways of adapting brushing styles with as little paint as possible. Practicing on a junker or scrap plastic is a good tip.
How is this turntable going to be powered… in theory as per the “real thing”?
if you spray the surface with dullcoat first, then let it dry and apply the powder, there’s no need to apply it (the dullcoat) after; as the powder will stick to the first coat. The initial coat provides “tooth” that holds the powder in place.
Also BRADGEON ENTERPRISES makes chalk powder with an adhesive mixed in, so you don’t have to spray the surface at all.
