Well I have ordered my ground cover material so it is time to disassemble the track so I can install the ground cover.
I have been testing this layout for several months and I think it will be fine. Smallest radius curve is 034 Marx, widest is Lionel 054.
Anyway I thought I should run some of my stuff that has been on the wall for years.
Thought you may like to see it.
Tks.
Kevin
Santa Fe (2) 218A Units (2) 218C Units (1) 218T (1) 8021B unit and (1) 202A Unit chassis with 8020 shell and 211 front truck. Pulling 19 cars some with heavy loads.
Also my Marx Williams Crooks 4-4-0 Steam Loco Wells Fargo set
Looks like a good layout to run a variety of consists in and out of the yard. I could not tell from the photographs if the yard has a run around track and \or crossovers. I m glad to hear that there is someone else who runs a layout prior to tacking everything down…it saved me some redoing that would have been tougher after the fact. That Wm Crooks looks good to go…!.
Nice start! I also have the Marx Wells Fargo set which was given to me before Becky was born! However, my set, I believe has only two cars. I assume you picked one up somewhere? What numbers are on them.
