Here is a Kato SD45 that I added detail parts to such as MU hoses, Signal Control Box, Lift Rings, Marker Lights, Sinclair Antenna. Also in locating the Signal Control Box in front of the Engineer, I filled the holes of the grabs on that side and drilled new ones on the fireman’s side. Painted with Scalecoat II Black paint and lettered with Microscale’s PC Set and Diesel Detailing Set.
Very nice SD45. This past week I tore out a curved section of track to widen the radius which required me to remove the tunnel/mountain. I also had to decide what to do with the old section of track bed as it wasn’t practical to remove all of it.
Views from the now completed Christmas Tree Central. The stream locomotive is a Proto2000 0-6-0 running on 15" radius curves under the tree. The blueness of the lighting is the result of my Christmas tree having all blue lights on it. The small tracks are Kato N Scale tracks with Kato Amtrak equipment.
I took some time this week to build some loads.
For the ballast cars (4) I cut a block of foam, painted it light gray and sprinkled some ballast on it so that the paint locked it in place.
On the scrap car I took a lot of old plastic wheels and cut the axles off glued them to a thick corrugated cardboard so there would not need so many. I sprayed them with automotive red primer, dry brushed lightly and touched the axle hubs with silver to simulate the new cut.
May not be perfect, but I’ll go with it.
What do you’all think? Have fun. [:-^] In case you didn’t notice the bottom picture is Proto.
I finally finished the first part of my winter scenery section, the town of Frostbite Falls. I’ve been doing some home remodeling the past several months and not working on the railroad. Here’s a few pics of the east end of town where the tracks cross in front of the dam.
I am almost done with my the Valley Cement Plant. I had to modify it some to fit in my layout and I still have a few minor things I want to do in the way detailing. I also incorporated the Pioneer Asphalt plant into it. And yes I know the 3 bay hoppers should not be there but until I get some 2 bay hoppers they will have to do.
Planted some more trees a few days ago and have another dozen almost ready to be planted. The locomotive is the Bachmann 3-Truck Climax pulling a string of log cars.
Well, it finally arrived. We heard about a Canadian Pacific excursion headed by a large T1c 2-10-4 Selkirk coming to Seneca Falls. After lengthy negotiations and some exchange of a few coins (do I hear a horse choking!?), the powers that be finally allowed the monster to come through Seneca Sub. Here it is, caught on my favourite spot:
