Weekend Projects completed!!!!! Additional PICS Added!!
My weekend is tuesday and wednesday so I thought I would share with you what
I accomplised this week.
The first pic is my body guard Harley. He waits for me patiently for hours while I am putzing around in the layout room.
[URL=http://i9.photobucket.com/albums/a72/scubaterry/HarleyonTurtle.jpg]
The next pic is a custom built DT-400 holder my neighbor and I built. We cranked out 14 of them. Total cost of materials, less than 15 bucks at Home Depot.
[URL=http://i9.photobucket.com/albums/a72/scubaterry/DT400Holder.jpg]
The next three are pics of an old cheap plastic LL dual main signal bridge I converted to bi-color LED operation. It only had little colored plastic beads representing lights. Three MM LED fit the holes perfectly. Unfortunately you can’t see the lights very good except for the night shot. You can see the detail better on shot #2. I used 3/32 brass rods to run the wires down. It was given to me and I put about 1.50 in it. I wish I could find more but they dont make them anymore apparently.
[URL=http://i9.photobucket.com/albums/a72/scubaterry/3sigbridge.jpg]
[URL=http://i9.photobucket.com/albums/a72/scubaterry/2sigbridge.jpg]
[URL=http://i9.photobucket.com/albums/a72/scubaterry/1sigbridge.jpg]
The next four are Dwarf signals made from PCB Vertical indicators. They came with two green LEDs so I replaced the bottom one with red. I used 1/4 square styrene for the base painted concrete. I know they are not prototypical but they are close enough. I have less than 90 cents in each. A Tomar Dwarf runs around 8-10 bucks. Now I can sit on my butt and run trains all day without getting up. I use DS-54’s with peco twin coils and micro switches on each T/O. I now have T/O position lights and panel push buttons for my yard. I love being Lazy.
[URL=http://i9.photobucket.com/albums/a72/scubaterry/4dwarf.jpg]
[URL=http://i9.photobucket.com/albums/a72/scubaterry/3Dwar
Seems to be working now.
Terry[8D]
Some hoods over the leds makes all the difference, if ya want!! Nice work Terry.
Ken.
Terry,
Looking good. I like the signal bridge. If you’re looking for something similar try Bachmann #45134, IHC #5014 or 5015, or Model Power #419. All three make the same basic signal bridge.
Nick
Ken - Actually there are hoods but not very large so they don’t show up. I thought about cutting them off and making some deeper ones out of black coffee stirrers that I have but I opted for the lazy route.
Nick - Tks for the info. I will check them out. It was a fun project and would like to do several more if I can find a cheap bridge.
Terry[8D]
Good work,but,uh, when did you sleep??[:p][}:)][;)]
preety cool man!!
Hey, Terry, those holders aren’t too shabby! They look to be very well conceived and constructed. Super job!
Selector - Tks we designed them so I can run a loco with it in the cradle. All the buttons are accessible. I had to do something because I kept drop kicking my DT-400’s all over the floor.
Terry[8D]
Im with selector. I like the look of the cab holders I need to design something similar for the NCE cab. it gets heavy after ahwile.
Terry, those look great and the price certainly is right. Can you tell us what you used for the sides? It almost looks like wooden “outside corner” trim, or do I need new glasses?
Steve
Steve - The sides were cut from a solid piece of 1 1/4 x 3/4 Poplar. We then made two cuts to remove the inside section and it does look similar to trim but much stronger. We beveled all the outside corners for appearance . So far I have assembled five of them and have them on the layout. Turned out much nicer than I had hoped they would and it is nice to be able to run a loco without removing the Throttle from the holder if you want to. I can take more pics from different angles if you like.
Terry[8D]
Terry,
I think I have a mental picture, but yes, a picture or two of the unassembed parts (if you still have any around) would be very helpful.
Thanks!
Steve
Steve - I will get the additional pics up sometime tomorrow morning. I still have six or so unassembled.
Terry
Steve - Here are some additional pics for clarification.
[URL=http://i9.photobucket.com/albums/a72/scubaterry/PartsforHolder.jpg]
[URL=http://i9.photobucket.com/albums/a72/scubaterry/EndViewHolder.jpg]
[URL=http://i9.photobucket.com/albums/a72/scubaterry/SideViewOfDT-400inHolder.jpg]
Terry
[8D]
Terry,
Fantastic, thanks a million! When you said 1 1/4 x 3/4 Poplar, I was thinking I’d use my router table. Now I see why you made two cuts, although I’ll still use the router for the first pass on the beveled edges.
Excellent job on the holders, and excellent pics showing us your design. [tup][tup][tup][tup]
Steve
Steve - That is exactly what we did. Before cutting the wood we beveled the edges with the router. When I had it assembled I hit the edges with my palm sander to smooth it up. Eventually probably will paint it to match the Facia color (which is non existant at this time)
Terry[8D]
Nice work, Terry!! An inspiration to us all! One of our club members has an “around the neck” holder that he had his wife sew up for him. He uses it for his DT-4r throttle. Pretty cool way to do it as the throttle is always right there as he walks around the layout.
John - I am pretty rough on my DT-400’s. I have dropped them so many times I am amazed they still work. A testament for sure for the DIgitrax folks. Now I have a pocket on both sides of each of the plug ins. Haven’t dropped one since.
Good idea with the around the neck. I need to get more of the IR plugins so I can go more wireless. So maybe I may have to try the around the neck thing to keep them off the floor.
Terry[8D]
Looks good. I would agree with the bigger hoods idea. Have you looked into different plastic straw sizes for these?
Keep us posted!
