Bought this car today at a swap meet, got it home before I noticed this bizarre attachment on each truck. It’s a Bachmann MOW tank car, the bottom says Made in China. Also a number, K181107. Can anyone tell me what this is and what I should do about it? It’s hinged, and I cannot imagine it stays on for running the car… it would jam in the ties. There’s one at each end.
Whal… thar ya go. Funny I didn’t see a track cleaning unit in the results when I googled that number. I’m not interested in a track cleaning pad so I’m fixin’ to cut it off or replace the trucks.
It attaches to a track cleaning pad. If you carefully remove it you can save it because sometime in the future you might find that you want to use it. Track cleaning pads are very helpful in keeping the track clean. I use them.
Hi Marlon. It was hard to take a photo that clearly showed what’s going on so it’s a little deceptive. The attachment is not mounted on the axle, although it comes closely underneath the axle and its hinge is right next to it. The whole thing is part of the truck frame. You either have to cut it off or put different trucks on. The wheels-and-axle sets in the truck are just like any other.
The problem is in the hinge, not the ability of the truck to pivot or ride properly on the track. If a pad spanning the railheads is not installed, any time that hinge is ‘leading’ and vibrates down it will foul the ties much like a car driveshaft with a failed front universal, and the results may be equally traumatic (to the railroader) and comical (to everyone else watching the resulting action).
In theory you could mount a short piece of styrene shape or card with a pin to hold it on the end, that would ride on the rails and not short or jam. But if you go to that trouble… why not just use a piece of inverted Masonite on a sprung pin in honor of John Allen?
I suppose, but I don’t even see why I would want anything dangling down to the rails between the trucks at all, since I won’t use this car to clean track. I like the trucks and the wheels, so I was going to cut the appendages off. But maybe I’ll replace the truck assemblies outright and save them for someone who wants to make a cleaning car (not I).
I do have one of the Walthers cleaning cars and only use it to do a preliminary pass or two on little used sidings and trackage I can not normally reach.
The backing plate is steel so has a bit of weight to it.
