What are these circles on EMD long hood ends?
Thanks Overmod. I guess I scrolled right past it.
Mike.
“What are these circles on EMD long hoods?” -
Port holes for hostlers performing reverse moves. [(-D] [(-D]
(i couldnt refuse)
PMR
I think EMD put them there because they knew it would drive the railfans nuts trying to figure out what they were.
Ken Vandevoort
I am a retired EMD Test Engineer. Both answers are correct. The holes are for optional Marker lights and can also be used to access awkward to reach Radiator Vent lines locate high in the Long Hood at the rear.
[#welcome] to the forum. Always good to see someone with real world experience. You are under moderation. I encourage active participation and the moderation passes quickly.
Given that you are a retired EMD Test Engineer and I am not, I will defer to your explanation. However, the optional nature of the holes seems a bit implausable to me.
Were the holes purposely designed to be optional, to be used for either marker lights or as access to radiator vent lines? What if a particular railroad chose to install marker lights? Could the marker lights be temporarily pulled out to reach the radiator vent lines and then put back in place?
It seems to me that the holes were designed to be used for one specific purpose, whatever that might be, but what do I know.
I think the mystery prevails, but my money remains on Ed’s explanation.
CN did not order rear class lights or rear numberboards on road thru freight units (GP40, SD40 and larger):
https://i.pinimg.com/originals/2b/b7/6b/2bb76bd96264f4ca0bbaa74eb123bf40.jpg
The secondhand SD40’s that were acquired during the mid 1990s are a bit of a crapshoot, they were all rebuilt to some extent but they all seem to be slightly different. The only thing they have in common is the front headlight was move
I’m late to this discussion but since my name is mentioned, I’ll chime in. For reference, I’m retired from EMD Engineering, working there from 1968 to 2015 with a few breaks.
Those blank covers do serve to access the vent line fittings as noted earlier by Lonloco and others, how often they had lights in them and whether that was the original intent, I’m not sure. Contrary to what some RR mechanics think, EMD did consider maintainability in all design work.
The EMD cooling systems are designed so the radiators drain to the water tank when the engine is shut down to prevent radiators from freezing. At idle and low notches, the radiators may not be completely full - the vent lines are connected to a port on the top of the water tank to insure the radiators will fill when the pump pressure is sufficient. At full throttle, there is a small flow thru the vent tubes back to the water tank insuring the radiators are filled.
EMD cooling systems are pressurized with a similar cap to an automotive cooling system, only much bigger. IIRC, the cap is a 12 lb. pressure relief and drains to the pit between the engine and equipment rack where it drains ultimately to the retention tank integral to the fuel tank. However, the design requires that the engine out coolant not exceed 210 deg F at full load at the design ambient, 115 or 122 deg F depending on wh
[quote user=“bogie_engineer”]
Overmod
I concur that Dave Goding is the likeliest way to a ‘definitive’ answer from EMD one way or the other.
Hesitant to mention this, but I thought the subject locomotives used an atmospheric-pressure system where the radiators drained completely back into the tank when the engine stopped pumping – do you not read ‘full’ on the gauge glass only then? I thought the necessary ‘siphon breakers’ were the valves accessible through those ports; other vent or radiator arrangements might not have them there.
Thanks for confirming what I understood was the function of the access holes.
Regards, Ed
Doesn’t the rubber gasket mount make them hard to remove and replace? It seems to me that a bolt mount like shown here would be easier to use.
http://www.rrpicturearchives.net/showPicture.aspx?id=1319920
Mark Vinski
