I am having a serious seniors moment and I need your help. I can’t remember the proper name for these strips. I have been searching Digikey for hours. I thought I bought them from Digikey before but my purchase history doesn’t go back far enough:
Pardon the fuzzy picture. Apparently I can’t remember how to focus the camera either!
I need strips that are two pins wide. The length doesn’t matter. They will be cut into 2 x 2 pin pieces.
They will be used to mount dwarf signals like these:
Yes, they aren’t exactly prototypical, but they are less than $2.00 each which makes then really attractive. We might try playing with them a bit to see if we can reduce the size of the housing and maybe add some duck bill shades over the LEDs.
They are called header strips. These are a slightly different kind than the ones normally found on PCB boards. Those have a square gold pins and sockets. These have smaller round silver pins and sockets and work great for more delicate wire installations for decoders that you want to connect and disconnect.
I bought mine off eBay. They came directly from China so it took a little while (2-3 weeks) before they arrived. No complaints on the quality though.
They are what I use for almost everything on my layout. They come in single 40 pin (breakable) strips as well as X2 dual row 40 strip or 80 pin strips in both female sockets (your picture) and male plugs.
The female will double as a male by soldering the wires to the socket side of the strip. I prefer the male plug as the male plug is slightly larger in diameter and fits tighter into the female socket.
The dual row header strips can be cut with a razor saw to make compatible NMRA 8 pin DCC connectors.
It is also easy to make polarized connectors by pushing out a male or female pin and replacing it with the opposite pin.
I stock both the single row 40 pin male and female strips as well double row 80 pin strips, I buy them off eBay in quantities of 10. That gets the price down to under 1¢ per pin.
Thanks. I thought they were called header strips but I couldn’t find the ones I wanted in all the thousands of Digikey listings. I have lots of the single pin strips buy I want some doubles for the dwarf signals. I probably bought the singles on eBay so I will do a search for the double pin strips there.
