I have a set of Athearn RTR F7’s that I would like to couple a little closer then they do.
What kadee coupler would you recommend?
I used #33 on My Athearn BB A & B units…one on the rear of the A with a #5 for the nose and the B has one on the front & rear…I also have the Walthers bellows diaphragms on them…but all My curves are over 32’’ radius. I also have the close coupler conversion kit for My Stewarts, which are freight AB’s, no diaphragms.
http://www.kadee.com/htmbord/page33.htm
Take Care! [:D]
Frank
This is the best close coupling system for the Athearn RTR/Blue Box F unit:
http://www.americanlimitedmodels.com/ho-athearn-f-unit-connection-kit-black/
Sheldon
I don’t own any Athearn RTR F units but if they still use the same coupler mounting as the blue box, it usually takes some effort to get a good proper KD coupler mounted and especially close coupled. The American Ltd kit listed earlier is the only commericial part I know of that is made to help ease close couple mounting of Kadee couplers.
LION couples F units with Drawbars. Him also has a power jumper for all wheel pickup. Necessary since LION used gaps to stop locomotives in the storage tracks.
ROAR
Lion,
what kind of material did you use for the draw bars? Also how did you attach them?
Dave
I do what Sheldon recommended and have enjoyed nice results. It is a quite simple solution and works well![C):-)]
