Ok I now own two large steam locomotives (PRR T1, ATSF Northern) now the Midsouth MRR Club operates many “turn” trains, for example the Marshall-Coldwater Turn, is a loads/empties coal unit train that operates from the Marshall Interchange at Shreveport to the Reddy Kilowatt Plant at Coldwater.
I often run my T1 as a NS revenue run between excursions of the T1 pulling the coal trains, when I reach Coldwater I must run around my train and run tender leading all the way back to Shreveport, what would the prototype practice for this be? Would I run caboose leading? And the T1 shoving the train? Or both caboose and T1 on front with the caboose leading? Or two cabeese? What to do?
Normally the engine would be at the head of train coming back, running tender first with the cars attached to the pilot coupler, and with the caboose at the other end. I have seen situations where a real railroad used a caboose at each end of a long train.
I suspect the layout you’re running it on is set in a relatively modern era? Unit trains didn’t really get going until steam was retired. I suspect if the situation you describe had been built during steam days, a turntable or some other turning method would have been put in by the railroad. With diesels, you can just run two engines back to back, so you don’t need to turn them around for the return trip in that type of situation. The engineer just goes to the other unit and runs the train from there.
Although there are certainly examples of steam engines running tender first on a line (and no doubt several people will cite examples of the same), railroads really preferred steam engines to run going forwards whenever possible. One of the reason railroads bought 1st generation diesels like the GP-7, RS-1, and BL-2 (BL meaning “branch line”) was because the diesels were better suited to running in either direction, and this allowed the railroads to eliminate turntables (or other turning methods) at the end of dead-end lines.
Simple the head brakeman rode the tender deck (on some Eastern roads this was called riding the high wind) looking out for any signs of trouble and that was in all weather.
A lot of engineers on these runs made home made back rest and would sit sideways while leaning out the window just enough to see along the side of the tender which had the same view as looking along the boiler when going forward.
Simple answer : don’t put that engine on that train (a PRR T-1 would be a horrible engine for a coal train), back the engine to the first place you can turn it, or leave the train and take the engine someplace to turn it, then bring it back.
If it was a train on a branch someplace they would just run the train backwards. However steam engines tended to have very severe speed restrictions running backwards. An engine might be rated for 50-80 mph forward and only 15-30 mph backwards. If its out on the main track with higher speed traffic, then they might only run it backwards until they can turn it.
You probably aren’t going to have a caboose on both ends of a coal train on the main track, from a train makeup standpoint its a very bad plan, having essentially an empty ahead of a loaded coal train. The slack runs in and will pop that caboose right off the tracks.
(And before everybody piles on with the “he can run what he wants” comments, he asked what the PROTOTYPE would do.)
Use a smaller locomotive and take it slow… A lot of logging and mining roads were adept at running steam engines backwards, but those were often with Shays, Moguls or Consolidations, with rear facing headlights and pilots on the back of the tender.
You don’t need to use a small engine. Large engines were used to work the coal mines in Southern Illinois and Western Kentucky.
It was normal operating procedure to run tender first on the mine runs. The IC used 2-8-2s, 2-10-2s and 4-8-2s for those duties. There are plenty of photographs of these locomotives with large locomotive headlights mounted on the tenders, sometimes on platforms a couple of feet over the tender deck.
They used what they had, but Moguls and Consolidations didn’t seem to be the first choice, at least for logging, with their “creative” trackwork. I’ve seen lots of 2-6-2’s, 2-8-2’s, and 2-6-6-2’s in logging service. I’m pretty sure that little trailing truck wasn’t put there just to hold up the back of the engine.
For mining, I suspect the need for trailing-trucked locos was lower because the trackwork was probably better. They ran heavier loads (I believe) and they didn’t relocate the mines nearly as often as loggers relocated load-outs.
The DM&IR used 2-8-8-2 “Hill Mallets” to run ore cars from Proctor yard down to the ore docks in Duluth and back. The engine didn’t have a way to turn, so ran backwards one way and forward the other. These had a headlight, pilot, and bell on the rear of the tender.
