Hi all, Ive watched MRVP and other videos on how to lay cork roadbed and track. Do you use Wood glue or DAP cauking to secure the roadbed? How about the track? Nails, DAP, Ballast?
Cork = old days Elmers glue and T-pins to hold it down, now I intend to use caulk. Glue takes longer to dry but is probably cheaper, so the advantage to caulk is slight.
Track = caulk held down by push pins until it drys. There is no need to use unrealistic track nails now.
Ballast diluted Elmers/alcohol spray,tho’s some people say diluted matt medium is less noisy
The is no need to rush the ballast. Make sure you track is reliable before you start on that.
Thanks Henry. Interesting about the Matt Medium. I’m creating a new yard and don’t want to use track nails So thanks for the post.
I used sheet cork, from AC Moore, for my yard instead of roadbed cork. With caulk, it is hard to spread in a way that 100% covers a large flat area. Maybe some water would have thinned it, I didn’t think of that at the time.
I used caulk because I saw a you tube video of a guy who used white glue and the glue seeped through the top of the cork onto the objects he used to weight the cork down. For a broad area, maybe contact cement would be a decent choice too. Anyway I had bubbles, spongy areas where there was no caulk under the cork. I had access to syringes and needles and injected those “bubbles” with dilute white glue. The glue does in fact ooze to the top surface of the cork. A little wax paper prevented major stickage and I have no spongy areas now.
I mostly use nails (small brads) for the cork, adhesive caulk for the track.
I find it easier to make the cork follow the pencil center lines when using nails, particularly on curves. I have used caulk for cork and it works, but I think I have more control with nails.
I do use strategic pins for track when using caulk. Track is pressed into the caulk with a small roller meant for wall paper. The pins can be removed as soon as the caulk sets
Dave Nelson
I use tacks for the cork and track. Like these.
For me, it’s much easier to do the curves.
I use Homasote roadbed, but I glue it down with wood glue. Track is held down with caulk.
On the main part of the layout, the cork was glued to 3/4" plywood subroadbed using yellow carpenter’s glue - held in place until glue dried using 2½" nails tapped in about 1/4"…I had a 50lb. box of them left over after building the house. The nails were pulled out, by hand, the next day. Atlas flex track put down with track nails.
On the partial upper level, the cork was put down using gelled contact cement. Where Atlas flex track was used, track nails hold it in place - I use pliers to push them in rather than a hammer. In some areas, I used Central Valley tie strips, and cemented it to the cork using contact cement. This was also used where the tie strip was layed directly atop the plywood tabletop. I used the contact cement to add the rails, too, and it seems to work well.
For positioning the cork, track or tie strips, and the rail using contact cement, I apply it to both surfaces and allow it to dry as per the instructions on the can, then lay waxed paper atop the fixed surface - simply tear short lengths of it from the roll, and overlap each over the previously-placed one. This allows you to see centrelines when laying cork, track, or tie strips, and allows proper alignment of the rail when adding it to the tie strips. When the starting-end of the material you’re laying is properly aligned, simply slip the first piece of waxed paper from beneath it and press down to make contact, then follow along aligning and removing the waxed paper as you proceed. The waxed paper is reuseable an infinite number of times.
For ballast, I use lots of wet water and white glue - cheap, easy, and very effective. I’ve also used matte medium in some areas and it’s no quieter and is much more expensive. If you later need to move or remove ballasted track, the white glue can be readily re-softened using a liberal application of wet water. That ballast will be garbage, but the track can be cleaned and
I use disposable brushes to apply water-based contact cement to the bottom of the cork. Apply per directions is very important to using this stuff, but it works well, can often be peeled up cleanly when you do want to move something later, and is much less stinky and dangerous than the solvent-based stuff.
Applying sufficient pressure is important to making it stick. I use a 6" wide laminate roller to put the pressure on.
I spread caulk with a putty knife, then hold it in place with a staple gun. If I need to take it up, I use the edge of a putty knife. When the caulk sets, I sand the top of the cork with a palm sander after removing the staples.
For track, I use the same method, only I use a length of 2x4 clamped along the length.
Atlas track nails for both cork and track.
ditto
In the old days - the track nails. Now, caulk. Faster and easier. And still easy to take up if you don’t like something and want to redo it. Push pins secure it, in a few hours it is set well enough to start taking out the pins. For the track I will typically put 4 pins at the very end, one to either side of each rail, which keeps the free end from moving as I attach the next section.
I was using clear for everything - it comes out white but dries clear, so you can easily tell when it has set up (under the track anyway). I may use a grey for the track next time, so any ballast bare spots don’t show. Trick is to spread it VERY thin - the marks on the nozzle of the caulk tube make for openings FAR too big - find for running a bead around a window frame, but way too much for model railroad use. Cut just the very tip off to get a very thin line of caulk. Spread it thin. If you’ve drawn pencil lines for the centers to line up the cork - you should be able to easily read the pencil lines, it takes very little. My previous layout, ONE tube of caulk did all the track and roadbed on a 13x10 around the walls layout.
I use foam road bed and adhesive caulk for adhering both the roadbed and the track. A bead along the center line then an old credit card to spread it out, and then lay some scrap 1 X 4’s and bricks on the 1 X 4’s for weight and leave eerything alone for a day. The roadbed and the track are laid separately.
DITTO DITTO
If I can put an Atlas track nail in instantly to fasten cork down, how can caulk be faster than instant, which has to cure/dry?
The old days are still here and nothing wrong with them. Caulk has been around a long time so why wasn’t it used in the old days, whatever “old” means?
I lay track on a center-line which I draw - and if I put the nail dead on the line, it seems more accurate than having to eyeball where the track is to go, especially if caulk is obscuring it - unless you use translucent caulk.
I have never seen the advantage of adhesives to lay track and cork - you have to wait. I am impatient and I’d rather not wait. If I don’t like something or need to pull up, I can pull the nails out with needle nose plyers and relay. Again, no waiting.
If anyone objects to the nail head on the ties, no problem. After I have applied the ballast and secured it with a dilute glue or matt medium, I can pull them out.
Some may complain, hey, I bend a few nails. shrugs not a big deal to me - I toss it and move on. Still faster - plain and simple.
I can’t see the advantage of adhesive; I mean, after it has cured, you site down the rail and see, oh, it dried crooked, funs over. With nails, often all I need to do is push the rail a little one way or the other and it will hold in that position. Again, ballast plus adhesive will hold it permanantly after I am completely satisfied.
My table tops are foam, so every thing, track,building, roads ect. is held in place with caulk
Yes, with foam, it is going to limit you to adhesives because nails won’t hold that securely to foam. If you plywood or OSB or Homasote, nails work quite well.
Maybe if you were more patient you wouldn’t need to pull it up? [:)]
There’s no wait - you just keep right on chugging along. By the time you’ve put down a significant amount of roadbed, the first sections are now set enough to pull the pins and do the track on top of it. And by that time, you’ve exhausted your spare tiem for the evening so having to wait until the next day to continue is no bother.
ON my old old layout, the 8x12 donut hole one, I ran one of the loops in about an hour, although I was using WS foam roadbed in the rolls for that so basically it was about 3 boxes laid in continuous succession. I didn’t notch in for the diverging route of turnouts until the next session - just cut out a notch in the roadbed and pulled it off. Then it was a little more tedious as I fit in all the turnouts before finishing the second loop. Once the turnouts were in place, I filled in the empty space using the long rolls again. As I had the track lines marked, I didn;t even precut anything, I just ran a bead of caulk from oen turnout to the next, started at oen and and stuck the roadbed in place, and when I got to the enxt turnout, laid it down to cut where neded and then pressed it into place. There is no doubt in my mind at all tha tthis is faster than nailing. Even with regular cork. Plus no bouncing materials all over the benchwork while hammering on it. Ditto with the track, maybe even more because you need to be more careful hammering a nail in to track, you really need a nail set to get it below the rail top but not hammer it in hard enough to bend or break the tie. Pulling them out isn’t always sucessful, either. I can just slide a putty knife under my track and bring it up undamaged. I suppose I shoudl slavge the track off my old layout even if it’s all Atlas flex and I am using Peco on the new layout. At least I should salvage and sell all the turnouts, Atlas Code 83 #4s complete with a wire already soldered on for the frog power.
&n
