Knuckle breaks between car 99&100 in a 200 car train.
First, conductor gets on the horn to the dispatcher, and any other train he knows is in the area to advise them of what has happened.
He/she then gets to walk back to the break…when he gets there, first thing he does is close the angle***on the car forward of the break, so the engineer can recover the air on the head cut.
He then ties handbrakes on the part that broke away…he does not turn up retainers, they only work when the train line is charged…hand brakes, as many as he thinks(and that road’s rules) requires, then a few more just to be safe.
After he is sure the rear is secure, and will not run away if there is a leaker that allows the brake cylinder to equalize with the resevoir, he has the engineer throw off the correct knuckle, (most locomotives have at least 2 different styles, a E and an F in hangers) and then he grabs on the last car, has the engineer drag him up to the knuckle, stops, throws it on the last cars walkway, gets shoved back down to the break, repairs the busted knuckle, couples up the cars, has the engineer stretch the joint to make sure the couple made, (nothing like doing all of this, forgetting to check the joint, walking to the head end, only to have it plug again when you start moving…yes I did, and no, never again) cuts in the air, waits till the engineer has the air back on the rest of the train, knocks off the hand brakes, and if he is lucky and the dispatcher isnt too POed at them, gets permission for the engineer to back up enough to pick him up, otherwise, he walks back to the head end, call the dispatcher, and they get underway.
Yes, all of this work counts against the total time on duty.
And most locomotives still have 2 knuckles, at least one knuckle pin, spare air hose and hanger, wrench, flagmans kit(fusees, torpedos, red flag) on board.
Ed
