Opposed Piston Engines in Locomotives had Several Drawbacks.
The Two Horizontal Exhaust Manifolds, One on Each Side of Diesel Engine Block, were WATER-Cooled, adding a HUGE LOAD to Locomotive Cooling System just Cooling EXHAUST!!
As Snubbers ( Mufflers ) GLOWED RED on Long Hard Pulls this indicates the amount of HEAT in Manifolds Upstream from Snubbers.
As a Result, and because of Water Leaks caused by Vibration, Coupling Impacts, Cyclic Hot/Cold Operating Conditions and their Uneven Heating/Cooling, these Locomotives were always getting ‘Hot Engine’ Alarms and, then, Shutting Down, putting extra Load on Remaining Locomotives in Consist.
Oil Leaks and High Oil Consumption account Worn Cylinders and Piston Rings were another OP Locomotive Problem. Oil from Exhaust and Leaks Blanketed Rights of Way wherever these Units were Used.
When Cold, OPs would SMOKE on Starting Out and this alone would Preclude their Survival in the Pollution-Conscious World of Today.
F-M Locomotives were amongst the Best Haullers, along with Baldwins, so they were usually used in the Heaviest Service.
Heavy Service = Heavy Wear, so they were ALWAYS in the Shops. Looked Bad on Performance Reports, 5 Hours at Run 8 at 12-15 MPH does NOT Add many Miles to Monthly Mileage Reports. But, in the Same Service, the 567s would Slip to a Stop.
F-Ms, Maligned, Cursed, and, other than by Rail Fans, not Missed at ALL!
