I have two tracks running together into a mountain, but they are on different subroad beds. I’m not sure if the will fit into a double portal. What is the inside dimention of the Double portal?
Thanks, David
Thanks, David
David,
What scale? By visiting the Woodland Scenics web page…
C1156
N Scale Concrete Double
Outside: 3 7/8"w x 2 1/2"h
Inside: 2 7/16"w x 2 1/16"h
C1157
N Scale Cut Stone Double
Outside: 4"w x 2 13/16"h
Inside: 2 9/16"w x 2"h
C1256
HO Scale Concrete Double
Outside: 7 3/8"w x 4 7/8"h
Inside: 4 5/8"w x 3 13/16"h
C1257
HO Scale Cut Stone Double
Outside: 8 1/16"w x 5 1/4"h
Inside: 4 3/4"w x 3 7/8"h
Don Z.
HO scale double track portals, as measured off my layout:
Cut Stone:
Width of opening: 4 3/4"
Side height: 2 3/4"
Center height: 3 7/8"
Concrete:
Side height: 2 3/4"
Nick
Answer for HO scale: Not any too big!
At least not for double stacked container trains on a curve. Mine measure about 4 5/8" W x 3 3/4" H. The rounded corners on my WS concrete double portals are too close for comfort so I needed to raise them by 3/8 inch. I suggest using the larger cut stone version from WS.
PS: Look out for low bridges too!
I needed additional height as well as width on this WS portal. This is actually 2 double track portals cut just slightly off center and reglued. The keyway is the only telltale sign of this modification. The portal was widened the width of the stone, about 3/8". Would have liked more, but the seam would have been too obvious.
