I was going to title it best just because I dislike “What is the best boxcar?” threads but the forum won’t let me strike thru on the title. Can’t use quotes either.
My experience is with building two rectangular modules 2’ wide and 5 and 7 feet long. I didn’t know how deep to score the foam so (don’t tell my wife) I used a big french chef’s knife. Either my layout wasn’t accurate enough or the snapping of the foam didn’t happen exactly perpendicular, but I had areas
I am expanding the layout and I want to avoid foam extending beyond the bench work, that will require sanding to fit the fascia or back drop. I have sanded the previous modules and it is a holy mess, even if you simultaneously use a shopvac, particles of foam stick to the vacuum hose and to me.
The bench work is light enough that I can turn it upside down and trace it on the foam, or I have a craft paper 1:1 drawing of the layout that I could transfer to the foam.
I have a Hot Wire with the bow and the thing that looks like an ice pick. In my limited experience, I don’t think either is stiff enough to cut a straight vertical cut. At this point someone will demand to see a track plan.
Here it is. I thought I might leave the hard angles, my thought being it would be a quick and dir
I’m a ways from the foam cutting stage on the current layout (past ones have used several different messy methods), but have a set on order. Always trying better ways to do things.
Nah, not really. I live in a condo and cut it out in the living room with two saw horses. Nothing too serious the vacuum cleaner didn’t take care of. But then again I’m not too scared of messes. I’ve been making messes and cleaning them up all my life[:P]
The finer the better jigsaw blade you can get makes less mess than you think
Woodland Scenics sells a foam knife which has a long blade Xacto style blade.
This works well. Use a drawing cut like slicing bread.
Styrofoam may be “extruded” but it’s pretty grainy in reality. Unless you draw the knife blade through as you cut you will break out lumps.
Hot wire works really well but freehanding a hot wire cutter is very difficult to do.
I got fairly good straight edges using a steel rule, framers square or similar. A wooden straight edge also works because the Hotwire isn’t all that hot.
The main challenge is holding the wire square to the edge if you want a straight 90 degree edge. I also use a long surform tool to square up a cut edge.
i made a hot wire cutter that would cut to a foot high, and maybe a foot deep… it was on a laminate table that held 90 degrees quite well … het adjustment was through a light bulb dimmer to a transformer …
i got the nichrome wire off ebay and just spring ensioned it … the guide was adjustable and / or removeable …
i cut all the foam needed fr a layout 15 feet by 16 feet, and up to 9 inches high, and it was glued together with dap alex plus clear adhesive caulking …
I have glued foam on the benchwork leaving a little overhang and cut it off to shape with a pistol grip hacksaw that worked great. When I put the hardboard fascia on a little spray foam or tape or something else fills the cracks depending on the place and size of the crack.
Thanks for the ideas. I wish I had a bandsaw, but don’t.
Bosch makes a wavy edge blade for less than those Festoon blades and I recall a video of someon grinding the teeth off a blade to make a knive edge. Knife edge jig saw blades used to come in the assortment packs, but don’t anymore.
I also saw a video were a guy made a horizontal cutter with nichrome? wire so he could make thin pieces of foam for tunnel portals.
I’ll give the fine tooth blade I have a try and see what kind of mess it creates.
When I do this I notice it is easy to tilt the wire away from 90 degrees. You get a straight but beveled cut.
Ideally, you need a device to hold the wire frame at 90 degrees as well as a straight edge to guide the cut.
Setting up the hot wire at 90 degrees to a flat table and pushing the foam through would work better. Freehanding a hot wire cutter is just not easy to do.
I wonder if adding the guide from the bow and guide accessory pack would enable easier 90 degree cuts since it is intended to assist in making angled cuts.
Woodland Scenics video guide for the hot wire foam cutter illustrates how hard it is to make just a straight cut, let alone straight and square.
For knife cuts there is a hot knife type foam cutter.
For non heated blades I would guess a thin serrated blade like a bread knife would work better than a chef’s knife which is deliberately made with a spine making it wedge shaped. That would make for tough going trying to slice into foam. Foam is relatively incompressible and a thick blade would tend to split and crack the foam rather than slice it.
A non-serrated blade should be thin like a slicing blade. These are thin, very sharp, round tipped blades designed for cutting ham and the like.
Styrofoam is surprisingly abrasive when cutting with a blade. Sharpen often. Don’t use your wife’s cooking blades.
Teeth on the blade are not useful for cutting foam. That’s what makes the foam crumbs that go everywhere.
I’ve used the fine tooth saw blade, works fine, not that much of a mess. I’ve also used a serrated knife for carving and shaping. Also works great. A little less mess than the saw blade.
Not terribly tidy or clean, but I used a drywall saw to cut a round hole for a turntable. The edges were all hidden anyway. Maybe it’s not the right tool in this case, but if it’s what you’ve got and you don’t feel like going out, it’s something to remember.
Respectfully speaking no matter what you do there’s always a mess. Even when you eat you have to do the dishes.
Where did this big fuss and phobia come from about the static and mess from foam? Does foam have radiation in it or something I don’t know about?
It’s never nothing a vacuum cleaner can’t take care of. When you cut the stuff with an ultra fine-tooth jigsaw blade you can barely even see the micro particles of pink dust in the carpet fibers or on the floor. I’ve even cut the stuff on the kitchen counter as a work bench and probably had some in my sandwich[(-D]
Please read and follow these simple directions:
Dish soap for the dishes - vacuum cleaner for the foam. Lather-rinse-repeat. Kids Don’t Try This At Home! Follow directions with adult supervision only[(-D][:-^]
I’m just hoping everyone can find some humor today, after all it is Christmas!
Experience. If you sand foam outside, not only are you and the shop vac hose covered by small blue or pink particles, the grass and mulch is too. And the later doesn’t vacuum up easily.
It also give me flashbacks to my drywall hanging adventures.
