What I’ve been working on…albiet very slowely, along with the Nww Blight pooper Mik sent me.
Probabaly the last model using Aristos drive bricks under the current fiscal restraints…
This is me using up some of those left over peices from all them other Mack bashes. It started as simply a double cab glued together with two radiators minus the hoods, it was going to go over a battery powered chassis, but after I got it together and painted I added the extra hood units and really liked the way it turned out so I built up the chassis, which is a thick sheet styrene w/ 1/4" basswood stiffeners, and 3/16 basswood stock built up end beams.
Drive bricks will be Aristo centercab bricks, likely taken from another less used model, as I’m trying to refocus on my most primary needs, I will likely be boxing and storing my larger items like the Superliner cars until I can focus on building the outdoor line, so I will take the bricks from the F40ph
Why??[(-D] You got no place to run it. You need to quit working at the workbench and get back to working on the benchwork![:-^] Any time you want I open for a lend-lease option, so long as it would blend into a pre-1930’s time frame.[bow] Looking forward to seeing it completed. Especially if you ever get interested in lend-lease.
I would seriously be interested in acquiring something like a “shorty-freight-goose” should you ever get the whim to make something like that. Of course it would need to have the proper heraldry for “Chateau de Vic.” I’ve got the passenger transportation covered, but could use something to deliver the burgers and beer!
I sprayed it that color blue when I was going to use the body for something else. I’ll be painting the chassis black with silver for the grab bars and such.
Painted and decaled, note the double coupler up front, so I can pull everything [;)]
I’ll be giving a light weathering later on, but it came out much better than I expected. maybe I should send this over to Phil at HLW, he’d get a kick out of it, actaully might give them an idea for a future release :lol:
