I have a unit that will give a red flashing light to the end car it is designed to work with D.C. … and it does this, perfectly . However, I am using DCC and of coarse the power is A.C. and the unit will not flash . What do I have add to this unit to make it flash and where in the curcuit would I have to fit it.??? CPPedler
You will have to add two things:
- A diode bridge rectifier which today is just a chip to convert the ac to dc.
- a dropping resistor to keep the voltage under the requirements of the EOT device.
You should be able to fit both in a space roughly 1" square.
Thankyou ndbprr , I shall try to get the parts tomorrow . God Bless You. CPPedler
Geez, ndbprr, are you an electrical engineer, or something? You sure seem to have this stuff cold.
I’m impressed.[^]
