There are two kinds of signals and we must not confuse the two.
First is the “HOME SIGNAL” protecting an interlocking plant. Home Signals are always controlled by a tower operator in conjunction with the alignments of the interlocking plant. Typically the indication is STOP (AND HOLD) and PROCEED (with caution) Later the Yellow aspect was added, “Advance on Diverging route” as opposed to a Green Aspect which indicated “Clear” (on this track).
On NYCT a home signals displays with two three light heads. RED over RED is STOP, and btw is never displayed with other colors…
GREEN over GREEN indicates Clear road over Normal Route (Next Block Signal is not red)
YELLOW over GREEN indicates Restricting over Normal Route (Next Block Signal may be RED)
GREEN over YELLOW indicate Clear road over Diverging Route
YELLOW over YELLOW indicates Restricting over Diverging Route.
Typically HOME signals warn the train about what will happen through the interlocking.
BLOCK SIGNALS
Typically a single head, usually with a number placard which is part of the indication. Used to protect the rear of trains in front of you moving in the same direction as you on this track.
RED (over the number placard) indicates “MOST RESTRICTIVE” prepared to stop within one halv of distance of vision.
YELLOW indicates Approach (at reduced speed)
GREEN indicates Clear (May operate at highest allowed speed)
DISCLAIMER:
LION knows that this is a simple explanation, and is probably not in accord with most modern rule books. Most modern signal aspects are complicated and indicate allowed speeds.
On NYCT:
RED = STOP AND STAY (Some locations may allow a “key-by” usually with permission of the control center)
YELLOW = Restricting, expect next signal to be RED.
GREEN = Clear, the next signal is not red (but it may be yellow).
There are some s
