What sound card will fit into a...
  1. Genesis SD 75 M (HO)
  2. RTR Athearn SD45T-2 (HO)
  3. Proto 2000 SD50
These are the engines I need to put cards in. It is just hard trying to find the best fit.
Tahnks
Chesticus
  1. Soundtraxx Tsunami GN-1000 Emd 710
  2. Soundtraxx Tsunami GN-1000 Emd 645 or QSI Revolution-A with EMD second generation sounds.
  3. Soundtraxx Tsunami AT-1000 Emd 710.
David B
Wow Thanks and quick.
These will go in with out any modifications?
Thank you again.
Chesticus
The boards will live where the current ones are, but the trick is the speaker and it’s placement. That I will have to leave up to you.
David B
As long as the boards go in. I can deal with a little fabrication. Thanks.
The advantage of a “drop-in” lightboard replacement decoder is that it takes up zero additional space, it goes into the same space the lightboard occupied. Speakers aren’t that big a problem, at minimum a 1/2" round speaker and enclosure will go pretty much anywhere in a diesel if you look inside. Often a larger oval speaker will fit too.
BTW they’re sound decoders, sound cards are what your PC has to allow it play sounds.
The Digitrax 165 series decoders will repalce Athearn, Atlas, Kato and PK2 light boards and they have a socket to plug in a Digitrax Sound Bug decoder. The nice thing about the Digitrax Sound Bug is you can upload specific sounds to the decoder.
