Changes in what? The Y7 was very little like the Y6, if you were thinking the Y-7 was an evolution of the existing 2-8-8-2 design.
N&W got about a year and a half worth of work into the Y7 and there are documents at NWHS, including a diagram. I went back into the steam_tech archives and found
http://www.nwhs.org/archivesdb/listdocs.php?index=rs&id=2907&Type=Drawing [edit: this link is dead; see proper one below…]
Dave (feltonhill) might provide us with an idea of what else is there.
Figures from King’s book on the A, p.77:
Driver diameter 63”
Cylinders 26 x 30; valves 14”
GA 130 sq.ft.
“Heating surface” 7100 sq.ft. (with 23’ tubes/flues)
Superheater area 2900 sq.ft.
Starting TE 153,000
HP (probably IHP, he doesn’t specify) “estimated in the 8,000 range at 40 mph.”
He says: “The Y-7 would have been one of the most powerful steam locomotives ever built, and its potential horsepower curve would have suited it admirably for use not only on N&W, but on other railroads faced with heavy tonnage in the mountains.” One interesting thing to speculate on might be that, if this locomotive had been built, its design would have ‘qualified’ for production under the WPB restrictions in WWII – which railroads that built heavy articulated steam might have opted for this design instead?
On the other hand, he mentions that by the time the kerfuffle about limiting freight trains to 70 cars had died down, the A and Y6 were doing the job well enough. As King puts it: "The utility of the Y-7 – the districts upon which its capabilities would have proven advantageous – would therefore have been more limited than originally
You know, I had actually not thought about that. I can see arguments going either way (but will not discuss them here). Perhaps there are some details that survive at NWHS. My own suspicion is that N&W would adapt the design to what was needed, and that revision would not include a Belpaire… but that is only my opinion.
Oh, I thought it was an evolution of the Y-6. Well, I learn something every day.
I don’t see them using a Belpaire.
Would the turbines or the Y-7 be more cost effective?
Depends a bit on how you define it.
I don’t see the Y-7 as being as economical to run as the “improved” Y-6b. The ‘Chapelonized’ Y6 I described earlier would be even more economical, and probably just as fast as the Y-7 would have been.
Part of the discussion here implicitly assumes that N&W had a faster-freight service across the mountains. If that speed (not coal-train speed) fell within what a “Y-6c” (I joke this stands for ‘Chapelonized’ …) could achieve, there is no point in building a larger and less-economical simple locomotive just for that service… in the 1950s. Likewise, the improved A class with Q2-pattern boiler is already knocking on the door from the other side, horsepower-wise, and while the improved adhesion of the Y-7 would be a small advantage, it would presume a higher average number of freight-cars in every train.
Meanwhile, the turbine (1) had roughly half the horsepower of a Y-7, (2) cost greatly more per example than a Y-7 would, (3) developed roughly similar starting TE (175K starting, which is higher and, of course, ‘smoother’ and 144K continuous); (4) would have had better efficiency on coal and water; and (5) would have required different gearing for fast freight service. This was a locomotive intended to do a Y-6s job, not a Y-7s. Which is not to say it couldn’t be improved somewhat … but Tom Blasingame, one of the proponents of modern STEs (steam turbine-electrics) looked very carefully into scaling it up to 6000 hp; there were the same problems with fuel and water that PRR observed for the “triplex”/V1, even with the higher nominal system efficiency.
Since the TE-1 was analyzed as being cost-effective with contemporary diesels, I don’t have any hesitation in saying that it was seen at the time as competitive with recipr
Ahh… I see. Different usages. Would the N&W have considered a 2-8-8-4? I’m not sure if it was needed or not.
Not. The fact that N&W designed a large simple-expansion 2-8-8-2 rather than a 2-8-8-4, within a couple of years of the very successful A design, can be taken as one ‘proof’ of this.
If you look at servicing pictures of the A, you will see dramatic overhang. A 2-8-8-4 would require more. Plus more lateral-motion compensation.
2-8-8-2 has more weight on drivers. Perhaps more than expected, based only on the wheel arrangement, as the overhang provided for those lead/trail wheels is minimized in a way that is not usually practical for a two-axle trailing truck (where the pivot must be located very carefully so the rigid engine wheelbase and truck wheelbase both follow curves correctly).
Theoretically you could get an ‘A-and-a-third’ out of this, with proportionally better starting TE (from lower drivers, probably 63" for comparison with the Y-7). Presumably the ‘extra’ boiler length would be as a longer chamber, rather than increasing tube length (already on the ‘long’ side in the A boiler). With better balancing methods it might be possible to run as fast as freight needed to go without severe augment.
Too big for any sensible passenger assignment, except in wartime circumstances. Too big for fast freight. Not as good for coal trains as a shorter 2-8-8-2 of equivalent cylinder capacity…
In another list, we determined that Y-7 information is preserved here:
http://www.nwhs.org/archivesdb/detail.php?ID=90311
Isn’t it interesting that Dave (feltonhill) is researching what I believe is this very book, getting details on the J balancing? At the next ‘volunteer’ session he attends, he might report what Y-7 material is there… ;-}
Hi Overmod!
Link activated: http://www.nwhs.org/archivesdb/detail.php?ID=90311
I see your points about the 2-8-8-4, with more weight on the drivers being more important than a larger firebox. Like how the Virginian managed to get by with 2-10-10-2s in drag service. And there was no reason to build it…
Dave, please post that information if you get it!
Last part of post moved here: http://cs.trains.com/trn/f/740/p/213216/2416504.aspx#2416504. I felt it didn’t fit this thread.
Hi NorthWest
From what I have seen at the documents the boiler would have featured an extreme backward slope of inner and outer firebox , as in the A class boiler several times steeper than the steepest grade – why ? what was supposed to be gained by that ? a trifle bit of mass saving , yes , however at the expense of even shallower firebox space than typical with firebox-above-driven-wheels configuration . Main and coupled axle bearings would have featured the same or similar unique design as in the last batch A class , Baker valve gear and wheels of 15 spokes , same as in the A class and same btw as in a 52 class Decapod of smaller wheels and less than half the axle load – a rather coarse design for such a heavy machine . It would likely have had the blast nozzle design as in the A class , featuring six rectangular orifices arranged in a circle and of pretty much the same brutal anti-streamline compromised design at the transition from pipe to blast nozzle as can be seen in the UP design of multiple orifice blast nozzles for double chimney .
All in all Y-7 features look fully in line with hitherto N&W steam loco design , nothing new , nothing special - a locomotive composed of A class technology but with a different wheel arrangement , so to speak . That pretty much confirms my expectation , namely that steam development on the N&W would have come to rest on a platform of a certain level of basic completion , although that platform was more to the point than with other RRs . It is a bit disappointing to think the N&W would still have adhered to the same w/a and not have developed further the steam generation part of the locomotive - the extra mass involved in having a larger firebox volume by an behind-drivers arrangement would have more than paid off in performance .
Again , further development was being seeked in a total break of tradition – i.e. totally new unconventional steam ra
Juniatha, I agree that steam needed to come to an end, because of technical limitations. There were just too many things the diesel could do more economically, and steam just couldn’t advance technically enough. The same thing may be happening with diesels now, look for a thread on that coming up. My idea of modern steam is to have let the existing steam locomotives be run until the end of their service lives, and no steam built after 1960. All Extreem Steeam wouldn’t have been able to compete (except for possibly the “Hyper Heisler” in the other thread).
It is just fun to imagine what would happen if locomotives were to still be built through the '50s.
What things from ALCO do you imagine would have been built? (Sorry if we already discussed this, but I can’t find it discussed in detail.)
What new ALCO power in post 1947 years :
Since they still felt the burns from their three cylinder (ad-)venture , all power strictly two cylinder only ;
little ‘articulations’ on or about SE Mallets , less on other ‘Artics’ … yet finally a 2-10-4 of their own - and with advanced high tension steels becoming available maybe a 2-12-4 of some 100 t full b.p. piston thrust ;
a new strictly standardized GP 2-8-2 for secondary lines , a well balanced 2-10-2 succeeding the universal Berkshire ;
with Niagara success promoting it : more high wheeled 4-8-4 types and lighter 4-8-2 off-springs for lesser performance demands ;
However , in my view they should have revived the three cylinder machine in a fundamentally re-developed form , ousting the design weaknesses that had ruined them in the 1925s .
For that scenario I had put up drafts of some three cylinder types :
a dual purpose 4-10-6
a freight 2-12-6
a dual purpose 2-10-4
a definitely express 4-8-4
and another 4-4-2 .
Possible further types might have comprised :
the before posted 2-8-8-6 modified SE Mallet ,
a 2-6-6-4 dual purpose Duplex with 69 in wheels …
Regards
= J =
And we do not yet know that the N&W designers would not come up with something new. From what I have read, they were not yet at their wits’ end. Lois
Please tell us again where those drafts are located; I don’t have a good link…
What is your opinion of using any of the existing poppet-valve systems on three-cylinder engines, and what would you propose as improvement on those systems for this purpose?
I think you addressed this already, but you might reprise it: if retaining piston valves on these various locomotives, what method(s) would you use to drive them?
Why is the Duplex a 2-6-6-4 while the twelve-coupled is a 2-12-6 (and the ten-coupled a 4-10-6)? There is probably some straightforward reason but I don’t immediately recognize it.
Hi everyone!
A couple questions:
How would you solve the cutoff issues with the middle cylinder? Would you still use Gresley conjugated valve gear, or the “Double Walschaerts” valve gear used on some UP 9000s?
Wouldn’t a rigid frame 2-6-6-4 duplex be a little long-framed for most lines? Especially with 69" drivers. I know that it wouldn’t work on OW curves, but even some PRR lines might find it long.
Thanks for your thoughts,
NorthWest
Just realized that that acronym may be confusing. I am referring to the New York, Ontario and Western. Also, the sound that one listening to a 10-coupled wheelbase try to negotiate that line would make. [(-D]
Hi Juniatha!
I like your speculations about possible steam, but I’m not so sure about an ALCO revival of the three-cylinder concept. American 'roads weren’t too crazy about three cylinders in the beginning, only the UP wen’t for them in a big way with the 9000 series. The others just didn’t like the increased maintanance requirments for a three cylinder job. Shop crews weren’t too crazy about them either. I’m not ignoring the fact they were very successful in Europe, it’s just in the American scheme of things I don’t see how they would have worked out.
“GP” 2-8-2’s for secondary lines? Certainly. The older steamers down-graded to branch line service were going to have to be replaced sometime. I would think six-coupled locomotives would have been needed as well.
Duplexii? Only the Pennsy seemed to be true believers in the duplex concept, but as time went by who knows? If the Pennsy made it work others might just have been interested.
As far as Norfolk and Western is concerned as long as Virginia Tech was turning out steam system engineers and N&W was grabbing them as soon as they graduated who knows where they might have gone? Fun to speculate on.
There were a LOT more railroads that ‘went for them’ in the '20s; they just didn’t last when better balancing let the required HP be produced out of just two ‘bigger’ outside cylinders, and the maintenance pains of the arrangement outweighed the perceived gain.
A ‘first best’ reason for Juniatha’s revival of three cylinders is that they’re needed to take best advantage of the rigid 12-coupled arrangement, just as on the UP 9000s. Even with ‘unitary machinery support’ two cylinders would have too high a thrust, and that with 90 degree quartering.
Personally I think it would be better, if you want a rigid-frame 12-coupled engine, to go to conjugated divided drive, with four cylinders, all outside. But there is added simplicity and shorter rigid wheelbase in the three-cylinder arrangement. For me, much of the ‘future’ in it (for purposes of this thread) would depend on poppet valves making the valve-gear-packaging issues less critical, and on better fabrication and materials for the inside rod and its bearings, probably with full pressure lubrication…
Hi Overmod!
Certainly other 'roads went three cylinder, not just UP, but not a lot more, and as you said they didn’t stay around too long. I didn’t mention any others for the sake of brevity. If you’re a maintanance headache you don’t last too long.
I suppose a 12-coupled locomotive needed three cylinders to get the best out of it, but UP’s 9000’s were “oddballs” in their own right, really cool “oddballs” by the way, but no-one else tried the concept.
Ah yes, poppet valves. It’s been said they came too late for American steam designers to really get the hang of them, a statement that’s probably true. Had steam lasted, who knows?
I might note that it is my feeling if the N&W continued with steam, they would have built more J’s to cover the remaining passenger assignments as the older K2 class Mountains were retired. They may have created a new unstreamlined J1 class to cover some fast freight assignments. Lois
Why? The As were pretty good dual service locomotives. And the N&W saw, by the end, that streamlining wasn’t necessary, buying GP9s instead of the concurrent FP9s.
Juniatha? I’m still curious about your 3 cylinder solution.
