What to buy for a first timer with Atlas 83 track
ok so in about 3-4 weeks im starting my new layout but i dont have a clue where to start for tools that i will need all i have is the track and the corkboard as for tools not quite sure what to get have looked at micro mark and seen some of the tools they sell if anyone could point me in the right direciton with tools do’s and dont’s that would be greta im looking at the track straightner and the track laying delux but not the tube thingy which ppl seem to dislike, any pro’s and con’s would be great.
Thanks for the help
Nick
track hammer works great for track.
Xuron Track Cutter, wish I hade purchased one a long time ago. Great tool!
A fine set of needle-nosed pliers would be handy once or twice. A sharp and robust cutting tool to trim and cut roadbed material.
Addendum -Sorry if this is cheesy, but you already have the strongest tool going for you. …your determination to make this all work. [:D]
thanks have added them to the list
I made a yard stick tool. Use the straight edge to keep the track straight. Used the 1" incraments to drill 1\8" holes for different radius turns. (18",20",22", 24", 30"ect…) Stick a nail in one end for a pivot point and a pencil in the desired radius hole and draw your curves like a big compass.
Sharp exacto saw or rail cutters.
Files
Cheap soldering iron
Drills for feeder wire holes
Use nails if there’s a chance your going to change the layout around,If not, a thin layer of caulk or liquid nails works great for track and roadbed. (liquid nails is pretty permanant) DON’T glue you switches down.
Good luck! Keep us updated.
thanks lothar will add tohose 2
