I went to a train show over the weeelend and found this old, seemingly junk locomotive for the princely sum of only $10.00. The plan was to gut it, re-paint, decal, and detail it and use it as a dummy. Imagine my surprise when, upon getting it home and putting it on a test track, it not only runs but runs pretty well.
So now what? I’m not sure of it’s pedigree although I suspect it’s an old Athearn unit. I suppose it’s too old to convert to DCC but if possible I could put a high end decoder and sound in it and still be way ahead on the money.
So first of all, can anybody tell me for sure what brand it is?
And what are the chances of converting it to DCC or should I just go with my original plan and make a dummy out of it?
That is an older Athearn locomotive with metal sideframes and steel flywheels. It is the same vintage as my Trainmaster, and it runs real good too!
There is a clip beneath the motor that needs to be insulated to install DCC. This is how the motor is grounded to the “hot” frame. You should use Kadee 20 series (insulated) couplers. When you take the motor out, those old amber motor mounts will break. Athearn has replacements available.
Those motors can pull about an amp, so you need a higher current decoder.
If it were mine, I woudl keep it running just as a bargain hunting trophy. It looks OK.
It appears to be an Athearn SD9. If it runs well, then it’s worth trying a decoder in, but I’d start with a low-end motor-only decoder before risking an expensive sound decoder in it.
I found one of these in Milwaukee colors for about the same price. It runs OK, but the long wheelbase and 6 axles give me problems at a few points going around 18-inch curves. So far, I’ve only run it on DC.
You can buy a replacement can motor for about $25, drop the current draw to less than 1/2 amp, buy NWSL nickel silver wheels, and have a darn fine engine for less than $50. And at that point she’ll be ready for a decoder, and there’s a huge amount of room in the shell.
I’ve never had any problems with those wheels in any of my Athearn diesels - they pick-up current as well as any plated ones, and offer much better pulling power.
If you want to replace the wheelsets, though, your best bet might be to re-truck them with the newer Athearn diesel trucks with plastic sideframes, if they’re available for that model.
I did so with some older Athearn SWs, in this case to get the Flexicoil sideframes, and they were drop-in-ready…
Newer Athearn motoors will fit too, for a replacement. Or one of the many remotor sets with nice can mootors.
At one time I am sure NWSL had replacement wheels for the old outside bearing models as well as the newer ones, but they don’t any longer. Thing is, Athearn made these things mostly unchanged other than the upgraded motor and trucks for a long time, and the new parts fit the old frame. One thing you might be able to do it find one of the newer plastic truck ones with a smashed shell and swap parts.
No need to toss it, for $10 it’s a decent loco and for far less than a new one will cost you can easily upgrade the performance to thoroughly modern standards, and adding DCC is not really difficult.
Wayne i never had pick up problems with them but living in a dusty place and having a open surface they seemed to need cleaning more often , that is why i sugested replacments.
Athearn’s sintered iron wheels work fine if you keep them clean. Or since it’s got metal sideframes, you could do like I did and drill holes in the bottom of the sideframe and attach track wipers with a #2 self tapping screw.
If it’s a good runner on DC then it’s a great candidate to upgrade.
The only conversion I have done are non-sound decoders.
Re-motoring would make sense at this time.
As has been posted- -replace the motor mounts. Athearn makes insulated motor mounts for this purpose.
For the electrical path; from the rails to the wheels through to the motor I prefer to isolate the trucks from the frame, and the motor from the frame as well.
Some will advocate still using the frame as a conduit from the trucks to the motor. I have done this but it invites a potential catastrophic event. (Don’t ask me how I know, I just know.)
By isolating the frame you do not have to be as concerned with the coupler trip pin(s) shorting on the track.
Using plastic draft gear boxes will also decrease the possibility of shorts through the all metal couplers.
I would also recommend converting the lighting from incandescent to LED.
Some decoders support LEDs without resistors. Also, using LEDs will also decrease the power draw compared to incandescent bulbs- -not to mention life-span.
Keep us informed on your progress and don’t be afraid to post more questions.
He must have of had what rrinker describes. Check out JJ’s link, scroll down and read rrinker’s post.
I’ve never had a problem. I have two BB Athearns, with the extra wheel “wipers” added on. They are soldered on the the same frame member that those that add the black wire to the truck, are soldered to.
If the frame is still hoot to one rail, and yuou use all metal couplers connected right to the frame, then the two WILL short if one is placed with the frame grounded to the right rail and the other with the frame grounded to the left rail (back to back). No way around that other than to use the insulated shank couplers, or grind the mount down and put the couplers in a plastic box, screwed to the frame through the ears and not the screw hole in the middle, which can touch the coupler shank when pulled or pushed. It may not be super noticeable at first - the blackening on the couplers isn’t super conductive, but as the couplers wear with use, it will get worse.
If the trip pin is hitting a rail, you have bigger problems than a short.
Actually, I had started a post about the short throough the couplers in that thread, then I noticed he said he was getting sparks running the loco by itself, so that couldn’t possibly be the short through the couplers problem.
